Kalapattar
Everything posted by Kalapattar
  1. A lot of stuff was removed and on the towpath! Generators, gas bottles, and other stuff but no stove or chimney or appliances
  2. An arson attack has been confirmed by the fire service a few days ago at Boxmoor Hemel Hempstead and Herts police are asking for any witnesses to contact lisa.brown@herts.police.uk
  3. Ok! Well Ive taped with aluminium foil the connections to make them more secure Yes I clean the flue and flame jet every now and then
  4. Yes, gases rise out, and I think the connections are loose to help prevent forced gusts of air extinguishing the pilot flame
  5. Ok, I thought you were stating gas pipe
  6. I’m trying to increase hot water supply under pressure to make a more powerful supply
  7. Yes I understand that. I’m trying to make hot water more efficient and use less gas
  8. Hi! A PWM controller was stated in another post! What is that please?
  9. My controller is what was supplied with panel! Not sure if it’s MPPT or MWP
  10. Hi! Shower hot water flow not powerful enough! turning up water temp on boiler and mixing cold to required temp must be the only way to achieve this I suppose!
  11. Hi! I’ve fitted a pressure pump and hot water output is no difference! What about ‘power shower’ heads? Would that increase flow? Booster pumps maybe? Ta!
  12. Ok, well mine is diesel powered I have a petrol generator!
  13. Ok, I have a recess in the gunwhale that sits a vent hole and cover presumably for such a flue!
  14. Ok, loosely fitted to prevent rain or condensation running back down to burner perhaps?
  15. Hi! I’m going to use aluminium tape. I’m just wondering why parts are loosely connected
  16. Ok, well the flue is positioned to exhaust out of the side behind fridge! I’m just thinking of taping parts together for more of a secure fit
  17. Hi! Thanks for your reply! I have no intention of using 12v. Only gas as stated in the topic. Ta!
  18. Ok, thanks for your post! It looks like flue parts are for flexibility!
  19. Hi! It’s an old 3 way fridge and exhaust flue kits are still available on EBay
  20. Hi all! I’m just wondering why my exhaust flue on a Dometic refrigerator is in parts? Is this just for flexibility? Should I tape them together to make it more secure because the joins are all very loose? Ta!
  21. Hi! I’m going to look at the water tank itself! Water flows from it but could be restricted
  22. Ok thanks! Hi! I couldn’t find original topic! Sorry! InS Instant gas heater yes! Morco Eco 6 ltrs pm
