Days Won
73
Posts posted by TheBiscuits
2 hours ago, IanD said:
Except that the W3W app shows your location and the destination and which direction it's in and how to get there, like any navigation app does -- I've used it to find people on a festival campsite... 😉
There you go with helpful factual information again. You'll upset those that don't do joined up thinking ...
But not so many members of the public
True, but most people can work out the letters from the words even if they can't remember it the other way round.
3 minutes ago, StephenA said:
Canalplan probably doesn't have it as a route for very obvious reasons.
Is it because Sharpness to Glasson is a more interesting trip? ⛵🛥️⚓😁
5 hours ago, StephenA said:
Canalplan has some locations which we invented and gave sensible names to....
Cropredy? Braunston?
At least try and be original! 😁😉🤣
44 minutes ago, Russ T said:
(I was trying to reverse the 4 to resemble a sail and mast, but its not that easy apparently)
You've done it successfully, it's just on the other tack ...
21 hours ago, IanD said:
or just under 1 femto-light-fortnight per litre, if you're a metric astrophysicist.. 🙂
Can't you just use microfurlongs per fortnight like everyone else does?
* Except bridge hoppers obviously, as that's too big a unit for measuring their distance travelled! 😉😁
23 minutes ago, magnetman said:
the EA database
I think that's a public record though and has less information in it than the now deleted website did.
I didn't get to see the website before it was taken down so I'm only going by what I've learned on this thread.
https://environment.data.gov.uk/dataset/9e6dfc4c-968a-4c2b-a020-ea7d97125002
The newest tramway bridge is now going in after some delays caused by weather.
I'm pleased to see it happening.
Just now, Tam & Di said:
There were, and as numbers grew it was becoming a problem so BWB tried to introduce the idea in the the 1995. It was thrown out at the committee stage.
Do you know approximately how many - dozens, hundreds, thousands?
The commission report says in 2025 there are ~35000 boats and 35% of those (~12000) say they are liveaboards.
As these numbers were taken from the CRT Boater Satisfaction survey I suspect there are some living "below the radar" who didn't state they were liveaboards.
5 minutes ago, tree monkey said:
The gabel end is now fully pointed with lime mortar, which as a bonus has stopped the driving rain being driven through the wall and into the bedroom
Ah, so like a boat anyway. Try Captain Tolley's
9 hours ago, MtB said:
Although I'm vaguely wondering if it might be the "Damian Hurst" effect at play.
Here's a Damian Hirst narrow boat ...
@StephenBarnes could you please tell us which AI you used to get this data, although I'm pleased you said it was no longer available from there.
10 hours ago, MtB said:
But easily rectified by deciding to buy a second boat, obviously....
Point of order: You can't have only two boats because they breed.
You either have just one boat or you have many boats, nothing else is sustainable.
2 hours ago, Arthur Marshall said:
Been good to know you, in the way we do on here.
"Electric friends" is how I describe most of the forumites when discussing topics raised on here.
The exceptions are mainly real-world friends.
And a couple of others are non-printable epithets. 😁
6 hours ago, nicknorman said:
Cold things radiate heat too. Well, unless they are at -273.something centigrade.
0K boomer 😉😁
3 hours ago, Iain_S said:
The obvious snag being that the "independent charity" will rapidly become Baton Twirlers Mk.2
Depends on who is involved. There's at least two names that immediately spring to mind as "shouldn't be allowed anywhere near it" candidates ...
38 minutes ago, Gybe Ho said:
Continuous Cruisers nearly doubled in the past 12 years.
Also specifically noted as an inaccurate term that should not be used by CRT ...
1 hour ago, Gybe Ho said:
Do your surveyor due diligence beforehand and be aware the best are reluctant to do private pre purchase surveys.
*Citation needed ...
37 minutes ago, frangar said:
I wonder how that is going to be received by various parties?
The NBTA will blow their top at a guess.
Recommendations for enforcing specified distance travelling per fortnight and per year, explicitly stating that "broken down" isn't a valid excuse, high demand surcharges for honeypot areas (esp. London and the western end of the K&A), actual use of the power to tow non-compliant boats away without the whole section 8 court palaver.
CRT will also sulk about it as they've been called out for their customer engagement processes and not having thought through some of their policies.
About the only thing the commission missed is that line in the byelaws about needing the permission of the board to use a boat as a dwelling place, but they did note that allowing boats to overstay in a fixed location is against charity law because it provides a private benefit for the individual(s) concerned.
5 minutes ago, LadyG said:
I reciev3d an I surance notice last night telling me my insurance runs out in six hours, what that dies is make me think about changing companies.
Didn't they send you one 30 days ago as well? They usually do.
5 hours ago, robtheplod said:
Not sure why they want to know if I'm Trans?
Just tick the "Don't know" option if you're not sure ... 🤣
19 hours ago, Mac of Cygnet said:
This from a notice about a pump-out not working:
Closest waterway: Leeds & Liverpool Canal
Starts at: Johnsons Hillock Mess & Services
Ends at: Johnsons Hillock Mess & ServicesDAK what is this mess?
There's a proper "mess room" in the building that contains the elsan and the (now closed) shower and toilet. Used by CRT staff and vollies as a canteen / break room / storage.
Major breach at Whitchurch on Llangollen
in General Boating
The "Gas isolation valve below" labels have become more accurate as well ...
