jacko264
Posts posted by jacko264
Try tapping the starter with a hammer on its side then see if it starts
You could try putting ptfe type around the olive before nipping the nut up you will need plenty of type
What colour will you paint it Ford major blue I hope 😀
Don’t quote me on it but I believe it has had some. Work done at the Humber end
Yes very enjoyable do you go down that canal ?
Graham
Weld or bold a bigger pulley to the front of the original crank pulley and move the alternator forward
it would need a bit of engineering and balancing
Any update on the water leak ?
I hope the problem has been solvedG
It would be a miracle to get a boat along that canal at the end we walked
the locks are derelict and the cut is full of bulrush
Part way along pocklington canal from the head
with our German Shepard .
the canal looked as if it had over flowed not long ago
Graham
If you fill the header tank it will not have any expansion room when the engine gets hot is there a fill to line on the tank ?
Grasping at straws is there any water in the sump with the oil
im just trying to figure it all out
I must stress it’s only ideas
Graham
Could it have a head gasket blowing into the water jacket ? Then blowing the water out the header tank . As the engine cools it draws the water back out the header tank ?
Graham
6 minutes ago, David Mack said:
The OP can clarify what his boat has, but usually there are hardwood frames on the inside, then tongue & groove planking, then originally masonite sheet, which the OP has replaced with buffalo board.
Ok I will leave it to people that know as I said it was only my idea 👍
So am I miss understanding I though there was wood planks then framing and buffalo board on the out side
Just a idea how about drilling holes in the outside panels and having polystyrene ball’s sprayed in or foam
then plug the holes in the panels
this is only my idea so ask around before doing it
The Flying Scotsman would be a great name for your boat Rod as you like trains too
It takes about 5-6 weeks at a guess she does not do it all at one time
G
- 1
It’s the time that kills the hobby money wise
your work is very nice and love the Wolf
G
Have a lovely Christmas and new year
Graham and family
- 1
There is no airbrushing involved in the picture all done with small brushes 😀
And thank you for all the lovely comments.
- 1
Thank you
there is nothing more rewarding to a painter then praise she loves painting .
I don’t know where she gets her talent from
NOT ME 😀🙈
- Popular Post
- Popular Post
Will a two pin shaver plug fit the socket round pin
Extended Tiller handle for cruiser stern boat opinions please.
in Boat Equipment
Many years ago I made a extended handle that slipped over the original by about 300mm.
then reduced down to the same size as the original brass one and fitted a wood handle on the end.
it was made off aluminium so nice and light and nice to use.
when I came to a tight corners I slipped it of until on the straight again
Graham
