well the old Reeves integrated steel poo tank problem. there is one fix that is fairly quick and less obtrusive, basically the boat is lifted out of the water and supported about a foot for and aft of the poo tank, the connections are undone and the whole tank is cut out from the bottom of the boat that section is then lowered with a fork lift and moved for carefull measuring. the new section of hull is then welded and a stainless steel tank is made to match the height and connection configuration the whole lot is then treated/ painted and lifted into position the hull is then re welded and blacked and the tank connected.
This solution minimised the ripping out of internal structures etc.
i know of two Reeves boats who have used this solution, one was only 9 years old and a 57x10 widebeam.
