Roland_65
    Germany, Kiel
  • Boat Name
    MakkeBeer
  • Boat Location
    Germany
Roland_65's Achievements
Gongoozler
Gongoozler (1/12)
0
  1. Hi Tristan, i am now the owner of MB. You can contact me via email Roland.Mittelstaedt@web.de best wishes Roland
  2. Now the gearbox is dismounted and on the way to my workbench. I still beleive it is a mechanical problem. The next days will hopefully show the reason for the defect. Last season i change the oil ( EP 90) but without effect. best wishes for next year Roland
  3. Which type of oil was the successfully one? Always when it sticks in fwd, it seems that the connection of clutch cone is fix and we have better propulsion.
  4. Hi CT, the clutch cone sticks always in forward, when we go for several hours forward or when we drive full power fwd, for short moment. regards, Roland
  5. Hi Richard, thanks for your reply. I try to remove the reduction box first, but with the same result, it doesnt move. I think the sealing sticks very strongly. Maybe glue is used. So far i understand you it is not required to temove the alu adaptor. I try to disconnect the reverse gear from his sealing using small hydraulic power, but without benefit. Maybe it makes sense to cut the sealing off. I will have a look tomorrow. regards, Roland
  6. Hi Richard, thanks for your reply. I try to remove the reduction box first, but with the same result, it doesnt move. I think the sealing sticks very strongly. Maybe glue is used. So far i understand you it is not required to temove the alu adaptor. I try to disconnect the reverse gear from his sealing using small hydraulic power, but without benefit. Maybe it makes sense to cut the sealing off. I will have a look tomorrow. regards, Roland
  7. Roland_65
    Lister LH 150
    Hi all, i bought a classic sailing boat with an Lister STW3 engine and a LH 150 reverse gear. Unfortunately it sticks sometimes in forward, so i decide to check the friction material of the clutch cone. To do so, i try to dismounting the reverse gear but it doesn't move off. Is it required to dismount the adaptor together with the reverse gear case? Thanks, regards, Roland
