Carl Heads
Everything posted by Carl Heads
  1. When the flu is fixed at the roof end I put wedges under the stove and undo the feet.remove theseand lower the stove. If the old feet have fixing holes in them ,use these on the new stove.
  2. at work we had a blocked macerator. If you look behind the pan you will find an anti syphon valve;make sure this is not blocked .
  3. Sounds like the contacts on the motor switch. You can take this off and clean the contact faces. Then get an old toothbrush and clean the armature by the brushes on the motor.you will have to unclip the mesh around the top of the motor to do this.Messy job and will take an hour or two Good luck.
  4. BCS are italian. You will probably find a Vetus prop will fit. Try Kings Lock at Middlewich
