nb cygnet
    Sandbach
  • Occupation
    Retired
  • Boat Name
    Cygnet
  • Boat Location
    Aqueduct Marina
nb cygnet's Achievements
Gongoozler
Gongoozler (1/12)
0
  1. nb cygnet
    Petter PJ3W
    I use Morris Sae 40 in summer and Sae 30 in Winter - it gets quite warm in the engine room - so hence Sae 40 in summer (I think Morris quote tropical ie +35degs). If SAE 40 is used in winter it creates quite a drag on starting. I am concerned in cold weather that the small bore pipes up to the top of the engine may starve the valves etc.. of lubricant.
  2. nb cygnet
    Petter PJ3W
    Ta Robin, this is a great help - perhaps I will leave it a another year - its not got any oil leaks of note, doesn't use any oil and it runs well - if a little smokey for ths first 1/2 hour. Maybe just the dekoke and check the valves. Ken.
  3. nb cygnet
    Petter PJ3W
    Hi Robin (sorry if you get this reply twice) Thanks for the info Jim looks like a good source. My manual says 40psi but I'm not sure at what revs, as the engine was designed to drive a generator at constant speed - as the speed varies so does the oil pressure - so waht pressure at 1200rpm? Surely it can't be 40psi at tickover. (Or perhaps I'm trying to talk myself out of a full strip down!!) Perhaps a question for Jim? As my wife has reminded me, its decorating at home this winter - so it looks like a job for the new year!! Ta again, Ken
  4. nb cygnet
    Petter PJ3W
    Ta Mike, Looks like a good source Ken
  5. nb cygnet
    Petter PJ3W
    Mine starts at about 65/70 but after an hours running drops to about 25psi. Will be looking at bearings and oil pump I suspect, whilst I am doing dekoke. Might just try fitting a direct reading oil gauge first - in case electrical sender is affected by warm engine. It was supposed to have been reconditioned in 2008 - I have a vague invoice for that time so I would have expected better pressure. Any tips will be most welcome including good place to get spares/advice. Ken.
  6. nb cygnet
    Petter PJ3W
    New to forum - but glad to see someone has a Petter PJ. Mine is a two cylinder (PJ2W). Only had it for 2 years - hoping to do a decoke,fit reconn injectors and service the water pump in the New Year now I've sourced/got some spares. What sort of oil pressure does yours run at cruising speed eg 1200/1300rpm Ken (Cygnet)
