Hi,
We bought the boat from BP in 2000. Its a 62ft duchess class built by John Pinder. it was named Bristol and still is. The colour has changed a liitle though. Its now pale blue which makes it much cooler in summer. The leaking black windows are now royal blue and do not leak anymore.
original spec was:-
Kubota 1703D with PRM gearbox. 1 start, 2 domestic and 1 eberspacher battery.
Upgrades so far:-
same engine and gearbox, improved air filter and exhaust arrangement to make it quieter.
Bosch kc90 with alternator controller.
1 start and 6 domestics, 240v hook up and 1500w inverter/charger, the domestic back also runs the eberspacher.
Split charge relays removed from stupid place (miles from the batteries) and a large relay inserted in correct place.
Rev counter and engine temperature guage added.
Eberspacher diagnostic kit and service manual obtained (very useful).
Toilet enhanced with manual macerator and water buttons (the automatic ones still work for guests).
I've fitted thicker cables all the way down the boat to reduce voltage drop, which has had the side effect of making the eberspacher and toilet macerator much more reliable.
As you can probably tell, I got fed up with flat batteries and hours to charge them each day.
Little armchairs replaced with two wide IKEA chairs that convert into a double bed. We can now sleep six.
Roof vents replaced with brass mushroom vents, they look much better and don't leak.
We've replaced:-
water pump, fridge, cooker and TV.
I did have a little accident in May that made everyone else on the boat laugh. I was coming into the marina from Oxford. I was at full lock on the tiller, and, nearly full revs to make the turn. The wooden end of the tiller broke, and, I accelerated rapidly to the left (me not the boat). I just managed to stop myself from going over the railings into the cut. Still made it into the marina without touching the sides. I'm claiming skill, everyone else says luck!. Fitting a new tiller is a nightmare!
We're based at Wigrams turn, and, plan to cruise stratford, avon, Severn and into merry hill this summer, stopping there for the week before the bank holiday. I would prefer not to stop but work beckons, and I can walk to work from there. All this is weather permitting. So if anyones in the area or sees a very blue boat go by wave and say hello. The children don't bite often!
If I could figure out how to insert a picture from my PC I would!
Paul.
