Trev The Rev Posted August 30, 2006 Report Share Posted August 30, 2006 Hi I have a couple of microphor heads (toilets) that use 1/4" air brake tubing to connect to the compressor (not 6mm which is now common place). Does anyone know where I can obtain parts for the air line - notable a cheap and cheerful needle valve as the brass needle valve isolator I have to one head has finally given up. I can find loads of modern push fit 6mm valves and similar but they will not fit the 1/4" plastic tubing. Any help will be appreciated. Trev the Rev Link to comment Share on other sites More sharing options...
Hairy-Neil Posted August 30, 2006 Report Share Posted August 30, 2006 Try here:- http://www.kiowa.co.uk/ Link to comment Share on other sites More sharing options...
Trev The Rev Posted September 3, 2006 Author Report Share Posted September 3, 2006 Try here:- http://www.kiowa.co.uk/ Thanks for the site - Unfortunately it is undergoing mainenace so not available at the present. Link to comment Share on other sites More sharing options...
