Many thanks for this, it clears up most of my questions. I may well have it wrong in assuming the radiators recieve heat from the engine. I have a solid fuel stove that also heats radiators, I think I assumed that the engine heated them as well. So that leaves me two questions. The first is roughly how much anti freeze will I need, the set up is as you describe, from the engine manual it would be about 4 litres of antifreeze, but I doubt that applies to the tanks and pipes in the boat, a rough guide will do. secondlyhow do I get antifreeze or failing that inhibitor into a squirrel stove central heating system ? or is it not necessary unless very cold weather comes. I assume that what you all call a calorifier is what looks like a hot water tank in the shower room. Thanks Pat
