Can I swop-out my existing battery bank?
I am proposing to replace my existing 24vdc 390Ah battery bank (6No: Trojan C20 130Ah) with Leoch Pure Lead Carbon (PLH+C) batteries;
4No: Leoch PLH+C 150FT (12V C10 150Ah)
These will be series into pairs and connected in parallel to give a revised battery bank of 2S 2P 24v C20 360Ah.
My current system is charged mainly when cruising, by a 24v 80Amp engine (Beta 43) mounted dedicated alternator and 4 x 100w Solar panels via a Victron MPPT 70/15 solar charger, also via a "Victron 24v/2000w/50A MultiPlus" while docked and aboard.
The Victron MultiPlus requires setting-up, with the correct voltages for the different SoC's being programmed into the unit. The dip-switch setting options that are programmable for a 24v battery bank are as follows;
Option 1 Absorption voltage 28.8v Float voltage 27.6v Storage voltage 26.4v Absorption time 8hrs
Option 2 Absorption voltage 28.2v Float voltage 27.6v Storage voltage 26.4v Absorption time 8hrs
Option 3 Absorption voltage 29.4v Float voltage 27.6v Storage voltage 26.4v Absorption time 5hrs
Option 4 Absorption voltage 30.0v Float voltage 27.6v Storage voltage 26.4v Absorption time 6hrs
I understand from reading the Victron manuals that other parameters could possibly be selected, via software downloads, the inverter/charger being configured via a laptop?
After, over six months of correspondence with the battery supplier I have been given the following; "For your reference and only in general the recommended charge settings for PLH+C Series for float applications are floating stage 13.62V, absorb stage 14.1V and equalize stage 14.4V". I'm assuming that Option 2 is my setting, however, quite frankly with over the six months of toing and froing I've lost all confidence in the multitude of answers. I just need to know if my alternator is suitable (B43 KC K22178 200-05383 28V 80A ALTERNATOR IA1150 11.203.275 AAN5171 28V 80A) and what setting to select on the Victron MultiPlus and MPPT controller if this needs to be specific.
Alternator enquiries with manufacturer "Iskra", say check with battery manufacturer and vice versa with other enquiries.
Unfortunately Victron Lead Carbon batteries do not fit the space and I also want to avoid the topping-up regime of the flooded WLA, I'm also assuming that the 30Ah drop in capacity will be compensated for by the greater DoD and the increased charge acceptance. Although the stated number of cycles is far greater for PLC's I will be more than happy if they last as long as the existing Trojan WLA, given the savings on engine running and battery maintenance.
Incidentally the boat is gas-free and a 7KvA Onan generator is used for the heavier loads, cooking, washing machine, etc.
Apologise that the enquiry is a bit long winded, but wanted to include all the information, and convey, almost a like for like capacity swop-out. Hoping for some shorter concise responses;
Charge settings need to be: XX XX XX.
Alternator: FINE or New alternator XX required.
