Onewheeler
Posts posted by Onewheeler
  1. 1 hour ago, Bee said:
    Seen it done but towing a bucket from the stern. The Riqueval Tunnel in France, An electric tug (overhead wires so don't thrash around with a hookshaft) hauls a train of boats through with engines off, we were tied behind a Belgian boat and behind us were other boats so the Belgian boat must have had 50 tons on its bollards . As soon as we entered the tunnel he flung the bucket off the back on a rope presumably to keep it going straight. Can't imagine it made a lot of difference somehow. As for dragging a chain along from the front I've never done it but I must try it sometime as Bee goes backwards like an omelette in a pan.
    When we pulled around 100 T of convoy through Ricqueval (first in a line of nine) our boat bumped the side lightly once in the entrance portal and then carried on in a straight line. Didn't touch the wheel at all. It took VNF five months to invoice us for the trip though and they made it hard to pay.
  2. 1 hour ago, Iain_S said:
    On the original query, Midland certainly used to do a separate inner which was a piece of metal rolled into a funnel shape.  We used one for a while. Easiest method of fitting we found was to put the small end of the inner into the flue, then ft the chimney over the top. Tight seal between iner and flue, and also between inner and chimney, so no need to insulate the gap.
     We have a stainless one of those. We had a galvanised steel one which rotted in a year.
  3. There aren't many places that you can't turn a 18 m boat, and even fewer where you can't turn within five minutes of cruising.
    You can tie up pretty much anywhere on the towpath side other than near bridges and where the bank makes it difficult. There may be some local restrictions due to water voles.
    It is a lovely and unique waterway. Hope you get to Sharpness, a walk around the old dock and around the riverbank is always interesting.
  4. If (and only if) the hull and engine are not too bad it looks good value. The seller quotes three different BSS dates, all soon, could be worth an offer subject to survey and new BSS. The cosmetics can be done as and when you please. The external paint job looks passable. I'd get rid of the toilet and keep the porta-potti. OVMD!
  5. 11 minutes ago, Machpoint005 said:
    The tank would have corroded more at the top than the base, as that's the part that was always exposed to the air when it was in use. The bottom would always have been covered ...
    The tank that I took out last year on our shared boat was corroded in patches all over. One edge had gone from top to bottom.
  6. It does look as if it's integral to the hull. It should be easy to hack out the parts inside the boat with a reciprocating saw and/or jigsaw if the access is adequate, but there'll be some rough edges left which it might be possible to bend out of the way with a lump hammer.
    It looks as if the tank was made of thin steel so one hopes that the hull won't be too corroded.
  7. It might well be less than generally thought. The battery on the wife's car is so knackered that the central locking won't unlock if it's been standing for a few days, yet it starts with only a little wheezing from the motor.
  8. 44 minutes ago, DanielBiggin said:
    We have guys that fly from Manchester, Birmingham/East Midlands or Bristol airports and then often all fly in from those outer airports to Heathrow before heading off proper so if I can jump on a train or end up close to a regional airport then I am fine.
    Bristol is difficult. Saul Junction marina was welcoming when I moored there, a few people spending a lot of time on their boats and not too expensive as marinas go. ~6 km from two main line stations (on different lines) and rural.
  9. I've had two marina moorings. Both say in the small print "no residential use" but in practice don't care if people spend "a long time" on their boats. Indeed, many like to have a few people spending most of their time there as it increases the security. The only issue is that they do usually say not to use the marina office as an address for post (although neither have issues in accepting parts for a boat if you ask nicely first).
    Tell us roughly where you might be interested and I'm sure that someone will have suggestions. (But don't mention that London!)
  10. On 24/08/2020 at 21:48, PhilR said:
    What have I fettled today?
    After several BSS advisories over the years on the lack of low level ventilation I have finally killed 2 birds with one stone.
    I have cut out the bottom panels of the front doors (which were rotting) and fixed massive ventilation grills to both doors
    and beaded them up. Staining/varnishing is the next job.
    But I suspect it mighty be a bit draughty in the front cabin during winter with OTT ventilation?
    It took me 20 years to discover, and has never been noticed by an examiner, that the low level ventilation louvres on the front bulkhead are screwed straight onto solid steel.
