Hello All,
I have just bought my first narrowboat and I am in the process of fitting out the inside. The only major problem / annoyance that I have got is that the 12V distribution panel is in the middle of the boat.
I can understand why this has been done as it means the voltage drops on the cables are going to be smaller, but it just gets in the way a bit, whereas if it was at the rear it could be hidden away a little better. The question I have is do I move it to the rear of the boat or leave it where it is?
Some thoughts ...
As I am going to have my galley at the rear of the boat with fridge and cooker would this actually be better?
The heavy items of equipment in the front of the boat are going to be toilet and water pump so I guess as long as they are wired in 6mm and 4.5mm cable the voltage drop should be minimal?
The cables all run down the centre of the boat so are fairly easy to replace. Could I replace the main runs and leave the cables down the walls in place? (There are already joints between long run and wall run)
Any thoughts and comments would be most welcome.
Cheers,
Matt
