DaveP
Posts posted by DaveP
I lost two panels to the wind a few years ago. The household waste dump at Ricky was happy for me to wheel them in on a sack trolley.
Thames Water are obviously already experimenting with organic corrosion inhibitors....
- 1
1 hour ago, Ex Brummie said:
Have you checked the range of your flowmeter? They are not all ranging.
Specification quote 1-30 lit/min. Wifi already tested and working from middle of boat. Temperature max is 80degC.
Hmm, I'm running LO 6.4.7.2 - saved it as a .xlsx file, so see if this works...
12 hours ago, magnetman said:
I'm going to be using Limehouse quite regularly. The conditions don't make much difference for this Boat as it can deal with anything but it is interesting. I wonder what the protocol with the waiting pontoons will be if people turn up later than expected.
It is my theory that it would be convenient for Aquavista and the CRT if the lock became rarely used. I heard they are not taking visitors any more. It is still a CRT lock so is available for licensed craft but of course early exit is very nice. Like a private waterway.
Its upsetting this has changed but not all that surprising.
I'd love to see the spreadsheet it sounds brilliant.
So I went online took 8th March as an option and it said '8.08 to 13.56' then the slot was automatically allocated as 13.56. Looking at my tide tables this is -after- high tide so one would not really be getting anywhere. The whole idea is to use the tide to help you along.
What a rubbish setup. I wonder if the PLA has anything to say about this. Discharging a canal Boat from Limehouse after high tide who wants to go inward bound is not safe.
I've posted the spreadsheet (it's a Libreoffice one not Excel) in the Canalworld FB group as I can't see how to place it in the forums here...
- 1
As ever, CRT's left- and right- hands are entirely unconnected. Limehouse now needs booking through the licensing website - https://licensing.canalrivertrust.org.uk/PassageBooking - only open for tidal windows within 0800-1600 until Easter and then 0700-1900 (I think). Brentford needs to be booked separately if you're doing that passage through the same site.
If you want, I've done myself a spreadsheet that shows the available passage timings for this rather than having to paw through their pathetic user interface....
- 1
2 hours ago, MtB said:
I'd say the average small house uses a load more energy than a narrowboat, but that energy costs less than the energy we buy for our boats. So comparing energy costs rather than kWhs disguises the fact that narrowboats use less energy as a dwelling, than a house.
I did a little work on this a couple of years ago
My annual usage - continuous cruiser, full-time liveaboard (one plus partner about 50%).
Electricity - 360 kwh (90% solar, rest by-product of engine whilst moving)
Gas - 1,200 kwh (7ish 13kg propane bottles)
Coal - 7,200 kwh (32ish bags of smokeless)
Diesel - 3,600 kwh (360ish litres)
Average UK house (from some govt website, can't remember which one)
Electricty - 3,000 kwh
Gas - 12,000 kwh
So the boat's not too far off the house, especially for heating, presumably because of the crap insulation/stove inefficency/infinite heat sink underneath. But the diesel isn't directly comparable to anything really due to differing lifestyles and transport needs....
In the couple of years since I did that calculation, I've almost halved the gas usage by switching to lithium batteries and increasing my solar output/usage by 150kwh - which also shows how inefficient gas cookers are compared to induction hobs.
- 3
1 minute ago, SandyD said:
In a 57ft Boat?
It's got the old single lock next to the new one as a weir. I'd think it would be fine (famous last words) otherwise at the Two Boats/Cuttle moorings...
Nimrod refers to the wide between bridges 108 (Nimrod) and 107, East of Napton Junction (CRT Ref is
OX-043-003) Winding hole no2 refers to the one by the ex-Bridge Inn at bridge 109 (OX-046-001). Whatever they are, you'd be able to wind above Welsh Road anyway!
It's clear from the VAT notice (708/6), that the zero-rating is temporary, can only be applied by a company actually installing them (ie not by the end customer merely buying them for self-installation) and the only boats covered are houseboats and those on residential moorings paying council tax....
- 1
It will depend entirely on where you are. Are you in a marina or other mooring with neighbours? If so, ask around and see what works for them. If you are cruising around - what area(s) are you intending to cover? There will be places (in my immediate experience the Lower Heyford area is still and quiet on all bands and network providers) where no amount of kit will fulfil high-speed needs without radical out-of-box reimaginings. What speeds do you need to achieve, or is it merely a daily/weekly quantity of data that needs to be shifted? Is the phone video or merely audio?
6 minutes ago, truckcab79 said:
Actual manufacturer aside I’ve got a possibly daft question. Many of the inverters have 3 pin sockets as an output. I’m assuming that in all cases you can also connect them to cables to supply your sockets in the boat? The instruction manuals I’ve seen on line don’t seem to mention this. I can’t believe you’re meant to just plug in like a glorified extension lead. Or are you? Seems a bit Heath Robinson.
Done like this so the actual input to the boat mains circuit (generally a 16A fixed male plug) can't be energised both by the inverter and a shoreline/generator.
- 1
On 22/12/2023 at 18:38, MtB said:
Its always puzzled me how you licence your boat if you really do live on it without a land address.
Easily - there is no verification of the supplied data against the PAF or LPRN. I usually supply my planned cruising pattern without a problem. I did get rung up by CRT this year querying the lack of a postal address and they admitted that it wasn't necessary (their argument was they needed an address to send me things, I pointed out that they had an email address. They countered with sending physical items such as licence plates or keys - I replied that the transaction would be instigated by me and would be a one off for which I would supply a suitable delivery address. They gave up and admitted I didn't need one)....
Similarly, with insurance, they use their own address as a place holder. It did take some time to convince them that their requirement for a 'home address' coupled with the fact that I was insuring the boat as a continuous cruiser was somewhat contradictory, but got through in the end (fortunately the droid on the other end did not think of changing the nature of the address they wanted, eg 'marketing address' instead).
2 hours ago, john6767 said:
Am I missing something, just had the licence renewal email and that states 4% now and then 9% from April. So isn’t that it for the time being, or is there more?
That's the rises from Oct '22 and Apr '23 - so, yes, there's more to come....
One week - they said they'd announce it before the end of this month.....
38 minutes ago, cuthound said:
A 9% increase will apply from 1st April 2024.
I got my renewal notice yesterday. No mention of a 9% rise _next_ April, but from _last_ April (as well as the 4% in Oct '22). I'm of the opinion that we're going to get stung with inflation +10%....
4 minutes ago, magnetman said:
"...with our prior written consent."
OK.
I wonder if they will give this consent without notifying the resident of the mooring. Interesting potential for problems there.
It seems odd that one could pay a low rate for an out in the sticks CRT mooring then use vacant CRT moorings in city areas with no extra payment.
I feel it is not that simple.
Absolutely! But there's no harm in trying. And it's going to be even more fun involving different mooring managers, asking wich moorings are vacant (not just up for rent). The clause is poorly drafted as it implies the permission is issued on a general basis, not (as would be sensible) on a mooring by mooring instance. I'd have used 'space' rather than 'spaces'...
- 1
where does it say that ?
Most of the CRT moorings actually in London are residential sites. I don't think you would be able to stay on an empty residential mooring unless you have the permission of the contract holder because it is their residence even if the boat is temporarily absent.
May apply to online towpath long term moorings.
Intrigued now !
In my T&C document from 2021 -
"4.10 When cruising away from the Mooring Site you may temporarily use any vacant mooring
spaces available at any other mooring site managed by us with our prior written consent. You must
remove your Boat from any such temporary mooring it occupies when we ask you to do so."There is also a requirement to notify CRT (para 4.9) if you intend to be off your mooring for more than 28 days.
Given there is no mention of additional fees, my reading would be that this term is included in the fees charged under the mooring contract.
34 minutes ago, Midnight said:
Some interesting points around the complications of the home mooring v continuous cruiser license. Although we have a home mooring we will spend seven months away cruising this year. Not a dissimilar situation to a ccer who takes a winter mooring. Seems pretty much a recipe for disaster for a C&RT who can't even get the stoppage notices right.
Indeed, we're planning on spending 15 months off the mooring (which happens to be a CRT one), going down to London and back. Keeping mooring as it's cheap, and we might need to hurry back for parent care duty. Might even pick up a little win if people start moving off moorings in town - T&C's allow us to use empty CRT moorings on a temporary basis... Looking forward to potential befuddlements.
If you can design your own system, I'd also recommend craigsolar.co.uk - I've bought two sets of panels from him, both with personal canal-side delivery.
33 minutes ago, ditchcrawler said:
How is the flow, we are heading towards Stratford on the canal and then down the Avon
Don't forget that lock 54 (penultimate above Bancroft Basin) is closed today for gate repairs.
20 minutes ago, MtB said:
in that case given V = IR the internal voltage drop inside a cell with say, 100A discharge will be 100 x 0.003 = 0.3 Volts.
The power dissipated inside the cell will be 0.3V x 100A = 30 Watts.
This seems intuitively far too high a result so perhaps I've made a mistake. Or maybe that 3 mOhm value isn't right. Sounds to me more like the value for a LA battery.
Having looked a bit more - prismatic cells ~0.3mOhm, so complete batteries somewhere round 1.2mOhm....
10 hours ago, MtB said:
I doubt it. The internal resistance of LiFePO4 cells is so low that I'd have thought hardy any energy will be dissipated inside the battery during discharge.
Some basic calculations would reveal the amount of heating effect. Does anyone have any values to hand for LiFePO4 cell internal resistances?
I don't have direct references for the internal resistance, but believe it's of the order of 2-3mOhm for a 100ah prismatic cell. One will also need the heat capacity of the battery to calculate the temperature rise.
My most demanding supply is my washing machine, which draws 150A at around 12.5v for 10-15min (about 400Wh), this causes the batteries (a pair of 100ah's) to warm by about 10degC.
- 1
Canal boats’ green image goes up in smoke
in General Boating
No - that's why I noted the no. of people aboard. I'm on the side that boat life is not inherently lower impact than house dwelling; but there are important considerations that haven't been touched on in this thread, including embedded energy in creating the structures, and the environment in which they're placed....
