Thanks for the replies
It all started when i tried to check the brushes I was told to remove the very top yellow cap because I couldn't access the brushes through the side , I still cannot see how to get pass the metal mess there's no clips and it looks as if its attached to the yellow casing. I then did something really stupid , because the top two screws wouldn't budge I decided to drill them out,the screws quickly came away suggesting they are only short but the top cover still wouldn't come off, started to panic. I have since checked other vetus manuals and on some models these screws go all the way through the motor and down to near the tube. Iam now thinking I ve really messed this up , can i rectify this or will i need to replace the motor.I dont think the screws on this model go all the way through the motor as I could see a gap under the hole after drilling Please help any advice gratefully received
Are the top screws on some models only used to attach the cover if so will I be able to get away this , also will the bits of the screws inside (if any ) cause any problems
Thanks Colin
