Panya
New Member
Everything posted by Panya
  1. Thank you all for your advices! Because I don't have wet vac available at hand at the moment, I tried fishing it out and it was a success! I know it might sound like a bad idea as many of you warned me of the even worse consequences if I also dropped the hook in there. But I tested until I was confident that the attachment is strong enough but still thank you for all the heads-ups. Regards, Panya
  2. Thank you all! For now, I will attach a small hook on the tip of the endoscope and try to hook it up. Will come back to report if it is successful
  3. Hi helpers, Reckless as I was, I dropped a plastic cap of a water bottle into the pipe of the fresh water tank. I used the endoscopic camera to locate the cap down the pipe. Not sure if I lucky that it didn't go all the way through the tank yet. (See attached picture) The cap is sitting about 1.7meters down from the deck fill. Do you have any suggestion what would be the best course of action here? Thank you very much in advance for your advices! Kind regards, Panya
