Hi thanks for the help. It is the inner cable that is not quite traveling far enough both ways about a cm to short one way and the other. As to the fitting the control at the helm has been serviced and no play, the cable is new never used and it is tight at the mounting points. Very hard to get to not an easy job. I have put a new cable (Morse fitting) clip-on mounting on the gearbox so that it is secure, just not going far enough, if I get it going forward it will not quite get reverse gear
Hi all and thanks for allowing me to join.
I have a small problem with the gear selector on my Commador 2.2 engine
The travel of the cable is just a little short and if I get it to go forward it is a little short to do the reverse. same if I change it around, if it is adjusted to get reverse it is about a cm short for the forward gear selection. Very difficult to get to in a Colvic Watson 28.6. Has anyone any idea if is there is a cable that would have a slightly longer reach?
Cheers in advance for any help
