Hi Tony,
That's incredibly kind and helpful thank you for such a detailed reply.
I will go to the boat and draw up the pipe diagram shortly but to answer your questions in the mean time.
-I will check what the 2nd oil cooler is connected to. I did think it was odd I'd never seen another engine with 2!
-The engine used to be raw water cooled but at some point has been converted (perhaps not very optimally!) to a closed system (sorry not sure if that's the right term) at some point before I owned the boat.
- Yes it was the skin tank I bled - sorry I'm a bit of a novice!
- I have owned the boat for a couple of years but this is the first time I have completely changed the coolant so unsure if this is a repeat issue but have had some sporadic issues with overheating at various points so perhaps the system explains that!
-The cable ties were in fact my bodge after the fuel pump bracket sheared off recently but will make sure to find a better solution (especially as my bss is coming up!) So thank you for pointing that out!
I will bleed the top hose as suggested today thank you for explaining that so clearly.
In regards to the other potential issues, would replacing the rubber end caps on the oil coolers and replacing the thin hoses with larger ones be a good idea? Or would removing the coolant and flushing the system be likely to help in the meantime?
Is the U shaped pipe likely to serve an important purpose or could I potentially remove and bridge with straight pipe?
Thank you so so much for the guidance, so appreciated. I will report back!
