Yeah it's definitely a 3rd fuel filter not an oil filter, now thinking it might indeed be a lift pump issue as the other 2 are gravity fed
Yes sorry wrong terminology on my part, the lift pump not injector pump. Got the strainer out the lift pump and gave it a clean, I think your right about it likely being a lift pump issue as the first 2 seem gravity fed. Trying your suggestion out now to figure out where the problem is
-thank you so much for the advice
Hi Tony
Looks like its a lift pump issue as you mentioned. I loosened the outlet from the pump, fuel tap on while priming the pump and only a few drops came out. Is there a part of the pump that wears out? Do I need to replace the whole pump like for like or is there anything else that may be stopping the lever from priming? Lever moves just the same as usual, no stiffness or loose feeling compared to my experiences on other bmc's.
Thanks for the response so far this is really helpful.
