Hoorayforboobies
Everything posted by Hoorayforboobies
  1. That’s what I was thinking! trying to find 6”-4 1/2” reducer is the challenge! Also - I very much do not want a 6” flue but I’m guided by the stove collar.
  2. Thanks guys you’ve certainly helped a lot! one more question which seems to be the biggest headache of them all. the collar for the stove is 6” which can be sourced from the above establishment. I absolutely cannot find a cast iron roof collar to fit the 6” flue. They’re all for diameters up to 5” max. any ideas? to say I’m stuck is an understatement and I really cannot afford to buy a new stove. thanks in advance!
  3. Thanks guys! I’ve no idea if I’m honest. Came with the boat. Minimal info on t’internet of any use. would a standard 5” collar fit?
  4. Hi, apologies! I was about as clear as mud! Stove collar inside current. Photo attached. 5” external diameter + 4” internal.
  5. You sir get +100 points. that is exactly the explanation I was looking for. 4” internal diameter with 5” external. so to summarise stove collar pipe +/- bends Roof collar chimney/rain hat stove rope envirograf thanks again, you might just be the most useful human being I’ve spoken to all year. more plus points for the forum!
  6. Excellent info! Thanks! its 5” external diameter. As it stands there is nothing above the stove. Could you advise of what parts I need please? From stove collar to roof would be greatly appreciated! thanks! Thanks! It’s actually in reference to a bloodhound gang album. Worth a listen if your ears aren’t easily offended and your enjoy well versed prose.
  7. My apologies. I wasn’t sure if it was in the right place.
  8. Howdy! flue question. so much conflicting advice on the internet. I have a 4.5kw lily king stove with 5” collar but NO flue at all. Does anyone know if there is a flue kit out there? or if the morso 5” flue kit will fit? 5” is 5” which ever way you look at it or am I missing something? ideally I’d love a list of bits to obtain so I can fit quicksmart - it’s getting cold! thanks!
  9. Howdy all. flue question. so much conflicting advice on the internet. I have a 4.5kw lily king stove with 5” collar but NO flue at all. Does anyone know if there is a flue kit out there? or if the morso 5” flue kit will fit? 5” is 5” which ever way you look at it or am I missing something? ideally I’d love a list of bits to obtain so I can fit quicksmart - it’s getting cold! thanks!
  10. Howdy all. flue question. so much conflicting advice on the internet. I have a 4.5kw lily king stove with 5” collar but NO flue at all. Does anyone know if there is a flue kit out there? or if the morso 5” flue kit will fit? 5” is 5” which ever way you look at it or am I missing something? ideally I’d love a list of bits to obtain so I can fit quicksmart - it’s getting cold! thanks!
  11. Thanks! it seems much nicer in here with proper advice, as opposed to social media! I’m going to be wiring up the whole boat, including the engine.
  12. Howdy. I have a lister SR2 and I’m just about to start a fresh electrical install. Some specs you may ask for - lister SR2 + 12” pulley on flywheel - Lucas lra100 alternator -440ah batts (not lifepo4) - 3kva victron inverter and all of the usual nonsense. anyone completed a similar fit? Any recommendations for alternator upgrade recommended? Pretty sure mine is banjaxed in any case with low v at 3/4 load. thanks!
