bradwilko
New Member
Everything posted by bradwilko
  1. Yes it is overkill the bubble b1c1 is 4kw, I was more curious into the Prity AM build quality if anyone has ever used one. The back boiler is quite high up on my list, going from a narrowboat the rooms heated up easily when the fire was in but with the widebeam having segregated rooms to heat it up without cold spots I'm going to need to run the radiators or UFH and don't want to be running the diesel heater too much as I want to keep running costs down. Even if they can be a hassle sometimes. I added the NRG zone so that just the back boiler is thermosyphon and the rest of the system ie the radiators, UFH, and hot water are pumped when needed (would this still be the case that i wouldnt be possible?), the UFH will be the main heat source any suggestions on what you would change to make it less complicated.
  2. Hi all 👋, first post on here but probably one of many, I'm currently looking into the heating system I am going to install on my widebeam i was hoping you could take a look and tell me what you think and if it all looks ok. (Heating sorce: Solid fuel fire and diesel water heater Heating up - radiators, under floor heating and hot water) I am thinking of installing the bubble b1c1 corner stove with back boiler, also what are peoples thoughts on the Prity AM 12 ( https://fireplacesforhome.com/Wood-Burning-Stove-Corner-Model-Fireplace-Log-Burner-Solid-Fuel-Prity-AM-12kw ) multifuel stove? And also a webasto diesel water heater. All my heating appliances are going to run to the NRG zone 5 manifold wich does allow thermosyphon , I plan to have 4x radiators, underfloor heating and calorifier attached. The diagram is missing the PRV and the pipes from the back boiler to the heating manifold will be in 28mm. My biggest worry is the thermosyphon safety as it is going to run to the heating manifold so i dont have any heat leak. Any input would be appreciated. Kind regards Brad I've linked the NRG zone let me know what you think to using this as I can't see any post speaking about this or any manifold. https://www.nrgawareness.com/product/nrg-zone-4-5-6-32-32-28/
