Tim LLoyd
New Member
Everything posted by Tim LLoyd
  1. Posted just now As you have 1x dedicated 'shoreline' socket - maybe the rest are only powered via the inverter. Correct, at least I believe so. Is the Inverter switched on ? Yes Are the inverter 'status lights' working ? Yes, all normal. Is the inverter supply working (fuse OK) ? Supply to the inverter is fine Does the inverter have 12v DC input ? Yes Does the inverter have 230 AC output ? How do I check this? Have you checked the 230v feed itno the distribution (fuse) box ? Trying to work out where to do so. Aplogies, I lost electrical power, having reset main rcb to Sterling I got everything back except the 240v as described.
  2. A few weeks ago I lost power on the boat - a Collingwood wide beam built 2014 - and eventually traced the problem to a burnt out contact breaker behind the control panel. I have replaced the contact breaker and can find no other problems. I have checked all the fuses I can find, all fine. However, I have no 240v at all at any 240v socket, with 1 exception. I have 1 socket wired direct to shore power and that is working. Everything else on the boat is apparently normal. I am stuck, hopefully someone will have a bright idea. Thanks in Advance. Tim
