Evening everyone. New to boating and currently have an offer in on a 1997 Colecraft built to 10/6/4. Could do with some advise on whether or not to proceed with it.
The previous owner, who had her from new, seems to have taken great care of her with documentation, invoices, and logging of all expenses over the years.
However the more I read up about it, the more concerned I am about corrosion on the hull, particularly to the base plate.
This excerpt comes from the survey:
The base plate was originally fabricated using 10.0mm plate
(nominal).
Ultrasonic measurements showed the base plate to be
between 10.0mm to 8.6mm reducing to 7.5mm at the aft
outer edges.
Pitting was widespread at up to 2.1mm.
Is this level of corrosion typical for a boat of this age? The asking priced of £54k seems steep if remedial work may be needed sooner rather than later.
Will follow up with the surveyor on Monday, who didn't make any recommendations relating to this, but keen to get some other opinions too.
For what it is worth, the side plate has some pitting to 1mm and there is currently no galvanic isolator fitted, which I would do before connecting to shore power again.
Many thanks!
Hamish
