Good eve,
After a thorough jet washing of the hull, I have a few questions regarding the preparation works required, before I can even think about getting out the bitumen...
The boat is a 45ft that has been sat on the dry in a boatyard for several years. The hull has been surveyed and was deemed to be structurally sound and in need of some pad welding to the areas of pitting (I questioned the possible use of filler in another post and was told pad welding was the way to go)
1. Is shot-blasting the only option for taking back large areas to bare steel? Pretty much all of the level below the water-line has little or no remaining bitumen and as such is largely coated in surface rust / corrosion. The budget and location don't really make this an option where she sits so hoping that there is a DIY way to suitably prep this...
2. Along the horizontal ribs / braces, some of the sealant has failed and has come away. What is the best product to replace this with?
3. Where this sealant has been a long-time failed, there are some areas where the rust has gotten into the braces / behind them where it wont be possible to grind away or remove that rust. Should I treat this with a rust-convertor or similar?
Thanks for your wisdom...
