Hello everyone!
I have created my account as I am dealing with a frustrating situation with regards to my engine and haven't been able to get any proper advice.
I live on a 1930s trad stern narrowboat, with an old lister petter engine that is built like a tank - it rarely breaks down and has been running a long times without encountering many issues. However recently this good streak has ended - I recently pumped out a large quantity of water that had been sat in the fuel filter. The other day I went to check the oil which showed up all the way to the top of the dipstick (overflowing, basically). The solution was black and watery. I proceeded to pump the contents out the oil tank to find about 10 litres worth of what looked like diesel mixed into the oil - resembled Guiness in colour and smelt of diesel.
I got the RCR over to have a look and they took the boat for a spin, and said to remove any more diesel if it came back, and call him again if the boat breaks down. He said if I'm really worried to change the fuel pump as it could have got in through there.
This didn't exactly clear my conscience and I am wary that there must be a loose seal somewhere that needs replacing as diesel shouldn't be able to enter the oil. From what I can see online this is often through the fuel injector seal which can wear away. I'm also wondering if the water that was sat inside the tank may have rusted the engine from the inside, corroding a lot of the components so diesel could enter the oil tank.
Had anyone else experienced this? Is it, as stated by the RCR engineer, not a problem? Or do I need to tackle the problem before the engine is permanently damaged? Confused. Please advise.
