David Krause
    Leicester
  • Occupation
    Self employed
  • Boat Name
    Silver Cloud
  • Boat Location
    Leicester
David Krause's Achievements
Gongoozler
Gongoozler (1/12)
2
  1. Thank you so much. Will try this. Brilliant diagram btw. I
  2. No worries. The boards are part of the jetty outside though looking through window to the outside. Thanks though.
  3. Hi there. Hopefully this helps and once again thank you for your help.
  4. Hi there. I think I put a picture on further up the page. I hope that ok as I was struggling to find a small enough file.
  5. Thanks for that but I reseated all stainless steel and chrome fittings with marine mastic which comes on a roll so I would hope it's not that but will have a look. Thanks everyone for their suggestions. I'm going to give it another go.
  6. Thanks for that. I was thinking to take out and start again but will look at non setting sealant. I used a marine silicone sealant which has worked on the others but strangely not this one.
  7. Funnily enough I tried to show you leak by showering window with hose for 5 minutes but no water came through. I have this picture of the offending window though which is the large one to the back next to the helm. Thank you for your help though.
  8. Hi there. It's coming from rubber seal to hull but on the bottom of it. Though strangely it runs from under the aluminium frame and over the rubber seal which is why it's been driving me mad. I've carefully stripped off the original varnish which had Sadolin applied to it and applied 9 coats of yacht varnish to a mirror finish and don't want it getting damaged. Thanks for help. Much appreciated.
  9. Thanks all. I'll give another it another go with seamseal and see how I get on.
  10. Thanks for that. I'll Google your advice. Would there be any possibility of a maintenance man traveling to Leicester to do the job or would that be unlikely?
  11. Hi there everyone. I bought a Freeman 22 narrow beam in 2016 for restoration and have managed to restore it to it's former glory. One job which has on whole been successful is taking all six windows out then taking them apart replacing all internal seals and finally once together again refitting. I again used brand new seals all bought from Sheridan Marine. Five of the six windows are working perfectly but the largest by dinette table has leaked on and off from the start. I tried putting more silicone behind rubber and Captain Tolley's creeping crack cure to no avail. Please advise. I would quite happily pay for an expert to do it for me.
