Tetlow619
Everything posted by Tetlow619
  1. All sorted, tested everything individually and it's the inverter ..... caput!! Can't upload picture but I won't be buying it again, going for a combi Thank you all for your help πŸ™πŸ»
  2. Thanks Jonathan, more details to follow Checked battery indicators and tested with battery tester
  3. Hi David & Tony, thank you both for your advice. None of the circuit breakers have tripped. I've checked all the fuses and the rcds for the shore line, all good. The inverter does not work running off of the batteries alone, batteries also tested and are good. I will double check everything again this evening to make sure and test each individual component. Thank you for the advice, I've found a similar inverter charger for a decent price. Very great full for your help πŸ‘πŸ»
  4. Hey everyone, hope you are all well! Looking for some advice on shore line hook up. I currently have a shore line hook up linked to my inverter via rcds etc. The inverter used to charge the batteries through the mains but also powered my 240v appliances etc. For some reason it has stopped charging the batteries and doesn't work as an inverter from the 12v battery bank. I was given this inverter and can't seem to find one that charges the batteries as well as works as an inverter. How does everyone have their shore line set up? I know I will have to get a new inverter to power my 240v appliances when I'm out cruising but I do need to charge my batteries via the shore line. Thanks in advance ☺️
  5. No I'm only messing around! I'll get her fixed up, wouldn't do that to someone else, wasn't brought up to be a **** πŸ˜„
  6. Ah now that's some food for thought, I was aware of the ultrasonic test, the surveyor was recommended but is now sounding a bit odd! Thanks for the info Ah okay, yes I've learnt that bit already! Okay that's good to know! Looks like a plan will need to be put together as we are currently in West London
  7. Thanks Alan! The added weight is definitely a concern. Don't think you are allowed access to the Thames without a life jacket nowadays, sod going on it from Limehouse without one though, ice done that trip
  8. Yeah that's the way I'm thinking about it, patch one area then another will need doing in the near future. Looks like Streethay is the way to go, thank you! Yeah I'm learning this the hard way .... should have bought a campervan πŸ˜† Thank you for the advice! Thank you Tracy πŸ™πŸ»
  9. Hi Bee, Would a yard do the work without a survey? I suppose they would and plate everything to make sure it is all covered
  10. Hi Slow and Steady Very good advice, thank you!
  11. Hi Chewbacka, Yes there's no doubt something needs doing in one or more places. Again yes you are correct it is a rough estimate, I'm looking for advice on if that is a reasonable price from peoples experience with overplating. This is also another worry, if I pay a few hundred pounds to get it out and have a full survey and a hole is put in it I'm kind of stuck
  12. No problem, any knowledge and advice is greatly appreciated
  13. Hi mrsmelly, I'm starting to realise this point! Thank you!
  14. Hi Goliath, No this is my problem, the surveyor didn't give us a report (and didn't charge us) and didn't complete the survey so for the boat yard we had her out at to say Β£10k would that be a random figure or a figure for all 36ft of the middle and assuming sides? (as the stern and bow appeared to already be plated) A previous comment on this said Β£200 per foot was about right.
  15. Hi Movin' on Great shout thank you! I'm getting the feeling going further north will be better. Okay so the price is about right?
  16. Ah okay, that makes more sense now! Thank you for your advice πŸ™πŸ»
  17. Hi Tracy, Fair point, I didn't say I don't think I have to! I was questioning a quote off of no evidence of what work is required. This was a quote from West London. Is the material and labour cheaper up north then?
  18. Hello all, We have a 30 year old 50ft springer. We bought her 3 years ago and have just had her out for a survey for GJW insurance purposes. The surveyor started a hammer test and stopped within 10mins as he was scared he was going to put a hole in the Hull. From what we could see when she was out she had overplating on the bow and stern but none on the middle. I've had 2 boat yards give me a rough estimate of overplating at Β£10k+ without a survey report. Firstly is this a figure pulled out their arse when I don't even have a survey report and secondly if I do have her out again and overplating is required what are the dangers of it and is it the best way to go as I don't particularly want to spend Β£10k+ if I don't have to. Thanks
Γ—
Γ—
