Oil cooler replaced, all good. In the process of flushing the skin tank I realised there has to be a bleed bolt somewhere as it was clearly trapping air and there was other no way to remove it. I found it hidden behind timber framing for the floor, though it was seized solid needed a lot heat to get it moving. So I've test filled with water and it's running sweetly bang on 82c. Left it for an hour and the temp didn't move, so it looks like the original problem was skin tank air rather than calorifier. However, I'm still a bit stumped by the calorifier circuit, I've now got a hot pipe going in but the pipe coming out is still cold. Tried bleeding on the calorifier, got a spit of water, then nothing. Definitely not affecting the engine running temp though.
