Posts posted by lpp2
The problem has been coming on slowly for around a month or so. As for the watertight question i was refering to the joint in the pipework what lm asking is because this joint isn't leaking water could it be leaking air. Think I've put that right. lpp2
This might sound a daft question, just because a joint is water tight, that is no guarantee that it's also airtight, is that right, because if it is I'll replace the hose tomorrow. lpp2
Just followed the pipework from the strainer to the pump and found a length of around 6 inches long of what looks like blue drinking water pipe pushed into the black heater type hose and held by jubilee clips, could this be the cause regards lpp2
Yes tony its belt driven lpp2
It seems to be sealed if not the water would just run out and water is going through the system. lpp2
Drive seems ok on the impeller been no loss of flow of water which I would expect if the drive had packed up. lpp2
Good Evening
I'm sure this is a familiar topic to all of you judging the number of posts on the same subject! The story so far Engine send out steam from the exhaust after around 15 minutes, temp gauge at around halfway between blue and red if anything slightly more towards the red. Action taken so far tried 2 types of thermostat one with a slightly higher set point for engines that dont heat water for domestic use, ran with no thermostat, put thermostat back, changed the impeller on the jabsco pump, cleaned out the Bowman heat exchanger, found nothing radical inside it.. my cooling system is a raw water system, water is brought into the boat via a strainer through a bowman heat exchanger then shot out the back via the exhaust. The strainer is clear of any debris as is the intake. This is driving me nuts any help would be so gratefully received
regards lpp2
Good Evening
Hss have a metal thicknesses guage which im thinking of hiring to test the hull and of a boat i quite fancy, does anybody have any experience of using one of these.
thanks
lpp2
Thanks for the answers chaps l'll go and have another look.
lpp2
Where's the oil pressure switch!!!! Sorry to be such a numpty
Regards lpp2
Good afternoon
bought a oil pressure gauge, an adaptor (BMM4E1016) from callcut boats the only problem is l don't know where they adapter fits on the engine, the boat didn't have an oil pressure gauge fitted so l cant just trace it back any help or may pictures would be gratefully received.
Regards lpp2
Good evening All
could anyone recommend a book on marine diesel engines. I want to be able to carry out a service and be able to remove and replace broken parts.
Regards lpp2
thanks that helps alot
good evening. how much would you expect to pay for a remanufactured sr2 including repaiting so it looks good as well as being bomb proof. regardd lpp2
Rev Counter
in BMC
thanks for that tony its always a worry. the funny side of this pacemaker is that it sets of the older style alarms in some shops always makes me smile when the security guards come running over. l have a card to show them and that seems to satisfie them. lpp2
Rev Counter
in BMC
Thanks for all the replys wont br able to go near the alternatot as l have a fancy pacemaker fitted and not allowed to play with alternators or welding equipment.lpp2
good evening
anyome where l could obtain a reconditioned Sabb2g just love the sound of that engine. regards lpp2
sorry my typing skills are mot so good tjat should read " anyone know" regards lpp2
kier at bottany bay on the LL at chorley did my boat this summer. lpp2
thanks for the replys sounds like a few dodgy conteactors out there maybe use sheets if foil backed foam the sort used in the building industry. lpp2
Good evening how much should l expect to pay for having a 40 ft trad shell spray foamed. Anybody recomend a spray foam contractor in the north west. Regards lpp2
Rev Counter
in BMC
Thanks so much for all the replies, most useful. lpp2
Rev Counter
in BMC
Good Afternoon All
Is it possible to fit a rev counter to my B.M.C.1800. If you think it is, could you tell in a idiot guide way where to connect it too, all i have at the moment is a water temperature gauge.
Thanks very much lpp2
Good Evening
Could any member tell me how I go about fitting this
At the moment I have to reach down in to the engine bay and turn a fair sized, don't know what to call it round disc/ cup, which is full of grease, which is both a mucky and difficult job.
Any help/advice would be gratefully received.
Thanks lpp2
Good Evening
Can anyone recommend a dab radio that uses a cigarette lighter type plug for power. Don't have or want an inverter but have a cigarette lighter type socket situated in a perfect place for a dab radio.
Regards lpp2
Good Evening
Could a fellow member recommend an engine oil for my bmc 1.8.
Best Wishes
lpp2
Yes I bought the boat because all the problems highlighted by the surveyor will be sorted before I take the boat away, most importantly not at my expense. I included an extra amount of money to be taken off the price to allow for the unforeseen, which I'm sure there will be. Once the work has been completed I'll have the surveyor back to give the work the o.k.. To my way of thinking I've used the surveyor as you should, If he'd said walk away I would have, but he did say if the work is completed as specified the boat will be what I wanted.
lpp2
Overheating 1.8 BMC
in BMC
Good evening
after a very long night last night I think I've made some progress. I took the pipework apart where the water enters the boat and cleaned it, i then replaced all the pipework from the strainer to the jabsco pump, then replaced the belt driving the pump and tensioned it properly. Straight away when I started the engine it was obvious by looking at the strainer that the water was coming into the boat with much more vigour. I had a two hour cruise around lunchtime and im very happy with the result, but just bloody annoyed at myself for not checking the obvious first, thanks for everybodys help and comments.
Regards lpp2
