Posts posted by alan_fincher
12 minutes ago, Tony Brooks said:
If they rebuild the OP's engine at least he knows how it has been used and what he thinks is wrong with it. He should also insist on Calcutt telling him the implications of any machining that needs doing - e.g. Cylinders bored to the maximum or less, so allowing for another re-bore or not, or crankshaft ground to the maximum so once that is worn it would need a new crank.
He should also establish if the camshaft bearings will be renewed - I assume they would change the main bearings as required.
One thing sure is that it would not be cheap, but probably more thorough than rebuilds by jobbing mechanics.
Well these are the only prices they now quote
1. Rebuilt BMC “Long Engine”- an un-marinised but running unit £2143.20
2. Strip, appraise, clean and refit of your marinising parts, respray and test £720.00
3. Remove and refit engine from a vessel (only at our base) £720.00
So I think that is saying that even if you remove the engine and take it to them, the cost is unlikely to be less than £3K.
But I'm not sure we have been told what is wrong with the engine, have we? -
Yes Calcutt still say they can rebuild a customer's BMC 1500, but only offer an exchange service for the 1800 model.
That said opinions differ wildly about the quality of Calcutt's BMC rebuilds, so you need to do a bit of homework about what you would be getting in to.
Whilst I have owned a boat in the past with an 1800 that was a Calcutt rebuild, that rebuild was far too long ago to give any reasonable idea about what they might b like now.I know at least one forum member had a 1500 rebuilt by Union Canal Carriers at Braunston, and I think they were happy with it.
I don't think this one has been posted, (but could be wrong though!)....
NaplesA great deal of money for an unpowered butty though - even a converted one.
33 minutes ago, matty40s said:
I don't know enough about Gardners to know exactly what difficulties it could cause, but surely having the engine or engine components virtually touching the bulkhead ahead of it isn't exactly best preactice?
Nice to see the Heart Interface - it reduces the amount of ballast you woul otherwise require! -
11 minutes ago, Mike Griffin said:
Listers are good, but not sure about the air cooled models and they do tend to be smokey........
Only if not properly maintained, and frankly no more so than any other old engine.
The issue with Listers is that they will continue to run and do the job, even if totally knackered. Because of this they become neglected, because people don't feel the need to spend money on them, but spares are generally available for any overhaul you might chose to ultimately do.
What I will concede is that an air cooled model is generally louder than a water cooled equivalent, (but some of us don't see that as a negative!). If no water cooling is involved you are freed from any anxieties about things like antifreeze, or whether you have enough to avoid a cracked block when the temperature takes a sudden dive into the "sub zeros".
Other air cooled tyes include Petter and Armstrong Sideley, though you are unlikely to find either in a modern build boat - they are generally found only in "historics" -
4 hours ago, MtB said:
Unfeasibly cheap, I'd have thought.
I'm currently paying £243 per month for a 57ft boat, which is still cheaper than the nearby marinas. (I think!)
Interesting.
Our mooring for a 71' 6" boat on the Grand Union in Northamptonshire is currently £200 per month.
Offside moorings with water, toilet disposal and electricity to each pontoon. Access by locked gate and adequate parking.(Well, being strictly accurate, it is also £200 per month for our 40' boat, as it is priced by the pontoon, not by length).
8 minutes ago, MtB said:
Well yes it looks very much like the back end of a butty going forwards to my unedumacated eye, but I wouldn't know if it was a Bantock butty in particular. If there ever was such a thing. I've the vaguest idea there never where any Bantock butties. Could that be the case?
I think there probably never were. They was horse boats primarily. Horse boats were not "butties", other than those that ultimately went on to be used as such, (e.g. some of the LMS "station" boats).
I also don't know what the back of an untouched Bantock would have looked like.
There are BCN day boats of quite pleasing appearance, (like "Reg") In my view Isombard Kingdom Brunel isn't one of them. -
37 minutes ago, Ewan123 said:
I don't think that is a "Bantock" as described.
I suppose it could have used thecack end of a Bantock to form its front end. Even then, I don't buy it! -
6 minutes ago, IanM said:
The latest update is from 11:19 this morning stating that the closure notice was incorrect and that it is open for narrow boats.
The formatting of the post is a little confusing and has meant the latest update is a bit hidden amongst the other text.
That's unusual.
Normally the latest position is at the top, with the history appearing below. Makes more sense to me!
1 hour ago, PaulJ said:
Well it wont now they have announced its not shut!!
1 hour ago, IanM said:The had already said it wasn't shut in the bit you posted. It was you who said not good for show goers.
I'm obviously misunderstanding, but the latest status seems to say to me that it is shut.
If it is a balance beam failure I don't understand why they can't pass narrow boats via the no-broken gate. -
A quite expensive Canon compact camera, by the top paddles of a lock in the Atherstone flight. It was in its carrying case and to my surprise my son eventually retrieved it with the Sea Searcher, which latched on to the tiny press stud catch, nothing else being magnetic. His efforts were in vain though as after every attempt to dry it out, it never worked again.
I can't remember the exact sequence of evenfs, but it was running erratically. I changed the filter, but also wanted to check out the smalll gauze filter in the lift pump. When i tried to pump fuel through not much was happening. I was suspicious of the lift pump, and never got it started. I now wish to substitute the lift pump with a spare I know I have somewhrre,
Edited by alan_fincher
Thanks Tony - very helpful.
I don't think there is a self priming option, and if there were, I don't think we have it, as when a professional did the job, they certainly had the side covers off.
I'm pretty certain the fuel filter isn't the spin on type, but I'm not currently where the boat is to check. I know I have 2 different types of spare filters, so presumably each relates to differences between my two boats with HA2s, but neither type of spare I have is spin on.
I'm sure I have an HA manual somewhere, if only I could remember where that somewhere is! -
2 hours ago, TandC said:
I'm just in the process of selling my boat, and found the original brass plates with their build and serial numbers on.
The hull was built by Dami Marine, ARN number 4019, "Lockmaster" - and there is a plate for the Lister SR2 engine that is still running sweet to this day. I've no idea what date that original build was - guess late 60s/early 70s.
Now a bit of a Trigger's broom.... she's sunk at least twice... the first time rolling and crushing the wooden top, sometime in the 80s. At this point the steel top was welded on, and late 2009 the overplating was done, both Steve Malpus (now retired) of Oxford Cruisers Ltd at Eynsham on the Thames. She sank again in 2022 when the EA / hydro plant opened all the weirs by mistake and has been refitted yet again...
We've lived on her for nearly 20 years.
Look after them and they serve you well.
I'll be sad to see her go, but we've gone to the dark side and got a wide one.
Dami Marine? Another builder I don't ever recall having heard of, so presumably only ever built small numbers?
1 hour ago, Llamedos said:
I know this is an old chestnut, but it would have been handy yesterday if the lockies had been stationed on the middle locks to manage the boats through. Instead they were in their default location by the bottom lock and I suspect didn’t even know about the damage.
I feel sure they would be well aware of the damage.
However it has long beem my gripe at Hillmorton that all the vollies congregate at the bottom lock
They could usefully manage levels in the two intermediate pounds, and top up as required, but I have yet to see them ever do so, prefering instead to let deep draughted boats bounce along the bottom.
12 hours ago, Speedwheel said:
We passed them yesterday - they looked very well presented.
I must admit I had no idea that Hyades still had its wooden bottoms.
Historic Boats for sale online
in History & Heritage
Well if something that looks remarkably like that is considered suitable for exhibition at Stoke Bruerne.........
