Posts posted by Antony Perry
Hi waste pump stopped last night,thinking is fuse as button popped out on circuit breaker,wondering if fuse is easy to replace thanks.
Hi just had 5 110amp batteries fitted and a new 75 amp alternator. When charging batteries full charged at 13.4volts roughly but my bmi meter is telling me the batteries are only at 62 percent. Have been told many different explanations one is just concentrate on the volts just like a simple answer not very electrically minded thanks.
Hi when starting engine first thing sometimes black soot comes out of exhaust, any suggestions please.
38 minutes ago, Tony Brooks said:
That is why I asked him in his first reply, but he has decided not to answer. If they are fluorests they may need a new fitting/inverter,
The OP really needs to answer questions, even if he thinks they are not relevant.
Thanks for advice looks like they are cheap bulbs and not leds
5 minutes ago, MtB said:
Now that IS curious. Certainly suggests a power supply problem rather than anything to do with the wiring.
What make and model of bulb is it you've fitted, exactly?
Or if you don't know, it is an incandescent bulb or LED?
Or failing that, post a photo of it please.
Ipro lite plus 10 watt 12v
5 hours ago, David Mack said:
But does it flicker when the engine is running?
No it didn't flicker when engine running.
Hi flickered when engine not running tried new bulb still doesn't work,should I turn off all power and check for loose wires.
Hi my 12v wall light was flickering so I replaced bulb still doesn't work. I am not confident with electrics but would like to take it off wall and check for loose wires, any advice to do this safely appreciated thanks moe.
Many thanks for your help much appreciated
Hi many thanks for that could you please send me a copy over the tank on the right has a plastic dome over it and the other tank has a metal top on it with ear shapes either side guessing that is the coolant. Sorry for sounding stupid but still learning thanks Tony.
Hi I am new to boating have a diesal 1.8 bmc engine would like to check where I top up the oil thanks.
Hi we are new to Narrowboat engine maintenance, have looked in engine checked engine oil levels but can't find gearbox dipstick help please thank you moe.
Hi I am new to electrics on boat and some simple advice please.when cruising do I change from shoreline to generator,and do I turn invertor off when not needed thanks moe
Hi we have just bought our Narrowboat in Crick marina, have looked at some WiFi packages and would appreciate if anyone knows any reputable installers as we not quite competent to install ourselves thanks.
Hi boat is 58ft we have laptop tablet 1smart phone and smart TV. we will be continuous cruisers so will need strong Internet with unlimited data. we are reasonably capable and savie people.
Hi we are just about to purchase our first narroboat as continuous cruisers and would very much appreciate advice for best Internet provider and how to install equipment for WiFi. many thanks antony Perry.
Shower waste pump stopped
in New to Boating?
Thanks everyone.
