Hi Tracy, thanks for replying. There is no signs of fuel in the oil, however the priming pump does appear to be very flimsy. I didn't consider the primary pump being the cause but food for thought.
Hi Tony, thank you for replying. The filters both seem fine. As I release the air bleed valve on the first filter, fuel spills out ok. I have removed the fuel link to the second filter in and fuel seems to be flowing through there ok as well. As I mentioned to Tracy, the priming pump does feel very flimsy and doesn't always pump fuel through (and assuming if the priming pump is drawing in air, would make sense)
The priming pump is lever operated and is below the filter.
