Pete-T
Posts posted by Pete-T
  1. Thanks for the comments and advice everyone, following further searches for convertible units as suggested I've narrowed it down to 3 options, so its just a case now of getting approval from "senior management"
    Many thanks again.
  2. I'm having the kitchen refitted on our boat and have been asked to choose an LPG built in oven/grill. Our fitter says we could choose a normal domestic model if preferred but having done an online search LPG items seem to be rarer than hens teeth!
    Can anyone advise on where I can find an LPG built in oven/grill other than the few options I found at Midland Chandlers?
    Thanks.
  3. I'm preparing for my BSS inspection.
    I have a single 6kg LPG cylinder contained within its own dedicated locker at the rear of the boat. There is nothing else in the locker except the cylinder spanner and it is impossible for the cylinder to fall over as the locker is only just wide enough to fit it in. Does the cylinder have to be secured with a chain to comply with the test requirements?
  4. While doing a service on my Beta 43 engine I drained the agglomerator. On opening the drain screw black fuel came out for around a minute, but the fuel in the fuel filter was clean.
    Not sure what this means, is it normal as in the agglomerator doing its job or is there a bigger issue I need to address?
  5. Does anyone have any recommendations for a quality 4 burner lpg cooker hob for a canal boat. We would like to replace the existing old cooker but want a quality unit rather than the flimsey looking (Thetford) items which seem to be common in many Chandleries.
  6. Thats all great info folks which will be invaluable in choosing the right provider but it still leaves me with the same question.
    Can I avoid paying a monthly fee for the card when we will not be using it every month, only when we are on board?
  7. Thanks everyone for the advice and guidance I've now got an antenna and router, just need a suitable data sim.
    Apologies for asking what maybe a rather "duck egg" question, but all the data only plans I've found seem to come with a monthly fee. As novice leisure cruisers we won't be on the boat all the time so it would be a waste to pay monthly, are there sims you can buy for a set price and then just use until the data runs out?
  8. Can anyone recommend a wi fi package (router and antenna) for a boat. As a novice the choice out there is mind blowingly confusing!
    We are not continuous cruisers and just need internet to keep up with e mail and browsing/you tube etc. entertainment in the evenings when out cruising.
    I have found some information online but it seems to be a few years old and I'm conscious that there may be newer equipment out there.
    Thanks
    Peter
  9. 32 minutes ago, Alan de Enfield said:
    When cruising, do you travel every day, or moor up for a day or two ?
    How many hours per day do you have the engine running ?
    Have you undertaken an electrical audit to identify what your daily usage is ?
    Do you know how to do a battery capacity check ?
    It is no use if your daily usage is 150Ah and you only put back (say) 120Ah whilst running the engine (lets say you have 40Amp alternator which on average will give you possibly about 20Ah, so if your engine runs for 6 hours you will only be putting in 120Ah)
    What engine do you have and what size is the alternator ?
    Alan
    Thanks for your help with this, I fear as a relatively new boater that I can't answer all of these questions fully. However.
    1. when cruising we move every day and the engine runs for about 6 hrs.
    2. How do I do an electrical audit and capacity test?
    3. our engine is a Beta 43 but I don't know the alternator size.
  10. The batteries are connected to a marina shore line when the boat is moored for any length of time. They charge off the engine as normal when the boat is travelling. They are monitored via a  voltage indicator on our Whispergen system. The Whispergen however is defective and does not charge the system as it should, its only the voltage indicator whic works.
  11. Following a full days cruising (approx. 6hrs) and despite minimal use of lights and other electrical equipment (no tele.) during the evening, my domestic batteries are very low the next morning to the extent that my fridge warning light is on and the Eberspacher will not start due to low voltage. I've checked the batteries with a multi meter and they are registering 12.5 volts. Are there any other power saving measures anyone can suggest (turning off the inverter for example?) to make the batteries last long enough for the Eberspacher to come on?
  12. Just to round this topic up for anyone having similar problems.
    I can confirm that regardless of what is said about there being no need for a pump, my system does have one. I checked it as Tony suggested and it is working fine. I must commend Lockgate stoves for suggesting solutions for the lack of fuel problem via e mail, when these did not work I was contacted by an engineer who talked me through the process of stripping down the regulator and clearing the internal valves and filters.
    Stove now works perfectly.
    So I would recommend anyone with stove problems to make contact with Lockgate they have obviously upped their game for customer support, I have nothing but the highest praise for them.
  13. I'm having a problem lighting my Reflex Stove. I follow all the manual instructions, however cannot see any fuel being released into the bottom of the pot initially. All the necessary fuel cocks are open and my fuel tank is full but I suspect the pump may not be working as I cannot hear it or feel any vibration . Does anyone have contact details for a Reflex engineer in the Warwickshire area who I could call out to help?
