The inverter has a 240 volt input for when it’s in charging mode which I plug into the 240 ring main on the boat works perfectly on the ring main when shore power is selected , As a charger If I then select inverter power on the selector switch , I switch the input to the inverter off which is also fine
, However and this is the baffling thing, If the inverter is plugged into the one socket which is not on the ring main , but a spare from a socket on the ring main , it trips the RCD , Doesn’t trip on the ring main sockets at all , the cable is only a couple of feet and in good condition ,
