Benny
    K&A
Benny's Achievements
Engager
Engager (3/12)
2
  1. It wasn't something I intended to do often, just if need be
  2. I figured the 4 was an optional extra 😃
  3. Yeah terminal connectors bolted on. Unless the terminal blocks are a bit dirty but don't think this is the issue. That's interesting, thanks. I will shorten the leads to just what is needed, which given the close proximinity between batteries and charger, should be less that a metre.
  4. Interesting, thanks. The cables are 10mm 70amp as advertised but they look more like 8 mm diameter and that includes the rubber casing. Also, I purposefully kept the cables long in case I wanted to charge a stand alone battery at a distance. Will that cause more volt drop? Should I shorten them? Didn't know this. I swear I read on here that not deep cycling enough also causes loss of capacity.
  5. Ah ok thanks. The batteries do sit at 12.8 under load for a while when the chargers have stopped charging. They only gradually come down with demand. In fairness it has been harder cycling them down past 12.4 that charging them up.
  6. I think Loddon's point has worked. The charger is now staying on bulk charge and reading 14.6 on high charge, it was only reading 13.8 before. Just got to figure out how the settings work a bit better. I'm confident the battery capacity is fine. They've been up at 14.4 all summer during the day and we haven't run them below 12.1 . They still supply plenty of amp hours in the evening/night Really appreciate your help. Think its just a case of not understanding the charger well enough yet.
  7. Thanks for replies. The batteries were new in the spring and have been getting fully charged with the solars all summer. They still hold a great charge normally with the solar. I think the 'smart' part of the charger might be the issue. Thanks just looking through the instructions to see how to do this
  8. Hi, My new victron charger thinks the batteries are full when they are not. It switches to absorption and float way too early. When I try to manually change it, it just flicks straight back to float. The batteries thus don't get a proper charge and fall very quickly. Am I doing something wrong regarding installation or do I have a faulty product? Only other thing I can think is that the solar panels are causing it to think batteries are full. If so, how do I get around this? Many thanks in advance
  9. Who knows, but it's been 6 years and has remained consistent. Could part explain why I get such a build up
  10. Is there a shallow water bilge pump or water pump that can start drawing at, say, 1 cm or less of water? Does anyone use automatic bilge pumps in the cabin bilge? Have been using a hand pump oil extractor for years. Usually get about a gallon a week max in winter. Space between hull and floor is very small. So soon reaches floorboards. Have a large access space at bulkhead though on both hull partitions. I believe problem is poor insulation (condensation) and a few minor leaks. I'm aiming to refit windows and vents this summer, perhaps insulate parts of the boat better. I still imagine I will need to keep removing water from the cabin though. So I'd love to fit something to make life easier and catch it before it reaches floorboards
  11. What other things might they be? ? We have to break out the generator to run the wet and dry , big hassle for a bit of cabin water. Been using a hand pump oil extractor thing for years. Do it about once a week in the winter, probably get a gallon out each time. Think it's a lot to do with shit insulation (condensation) and maybe an undetected window leak. I'll redo the windows this summer but I imagine I'll still get plenty of cabin water in the winter. I was wondering if there is a shallow water bilge pump? Something than can start drawing at a cm of water or so? Or some kind of electric water pump?
  12. I can't find the input wattage for the charger anywhere so thought I'd ask those with experience! Thanks in advance
  13. Interesting thanks. How long do your lithiums last? Do they receive more charge off the panels in winter?
