People kindly gave me advice with an alternator problem a couple of weeks ago. Some collective wisdom on this one would be much appreciated............
When we hook our boat upto the land power supply the land supply trips. This can happen immediately or after up to one hour. In the latter case if we reset everything and try again, the cut-out is immediate. Also when we try a second time the next level up often trips (eg the marina, which endears us to our neighbours).
The external power supply is fed into a Victron Phoenix Multiplus 1200 which distributes the AC, converts to DC and manages landline based battery recharging. It also supplies 240V Ac if the landline is not present.
Apart from battery recharging, the only use of the landline power was to a 240V fridge and an automatic bilge pump which did not (and has never) switch(ed) on.
The symptoms have been repeated in 2 marinas (one with a 10amp breaker and the other with 16amp) with identical results. We have also repeated the tests using a different power cable.
If we take power purely from the batteries eg whilst cruising, we have no problems at all.
Thanks for any thoughts. Our boatyard has not been able to come up with any explanation and is now proposing to replace the Victron. However I would be happier if
there was a convincing explanation of what could be going wrong.
