RiverPuffFairy
Posts posted by RiverPuffFairy
3 hours ago, Detling said:
How will an totally exposed person get from the bedroom to the new bathroom?. If you have an overnight guest on the sofa etc would they have to pass them?, anyone coming from the shower will also have to pass through the boat to get dressed, there is a reason bathrooms are normally between the bedroom and accommodation spaces.
Quite easily actually, as I hope you can see from my (very quick) first draft of the plan. The idea is also a bathroom which someone could dress and undress in, which is completely impossible at the moment.
In regards to people passing me in the night to use the bathroom, I don’t think I’ll have a guest to stay who I would feel uncomfortable passing my bedroom at night ?
5 hours ago, Higgs said:
There's no way gravity is going to empty a bath/shower on a boat unless it's fitted above the waterline. Either need a Gulper or a pair of step ladders to solve some practical problems.
The work is not massively over complicated, and as cheap as you can make it, if you do it yourself; with time, tools and patience, and planning. Bulkhead, floor, plumbing...' what budget do you want to work with? Under a £1,000?
Thanks for your insight, I would like to keep it under £1k and if it’s relatively uncomplicated like you say that shouldn’t be difficult. The less I spend on labour the more I have to play with when it comes to things like tiles etc.
The current shower has a (gulper?) pump which I’m hoping to reuse... would that work for a bath?
The bed was made into a cross-bed, a wardrobe/cupboard was made to take 2 folding bicycles, the bathroom wall was moved to make it larger, a pump-out tank was removed and a cassette toilet installed and the area redecorated.
More than just a bathroom added to an empty space then? I doubt my final bill would come near to that even if I paid for the whole thing, but thanks for the information!
1 hour ago, Opener said:Not much helpful to add
Useful info though, I hadn’t put much thought into it and now I don’t have to ☺️
If you are doing it yourself then labour costs are Zero, just lots of tea for poor old dad, If the boat is that badly laid out why did you buy it?
We could probably do it all; it would be great if I could afford help. I got her for a good price, and I could see the potential with some relatively minor changes.
1 hour ago, roland elsdon said:Touching the hull probably only involve drilling a skin fitting hole preferably above the waterline, and fitting a skin fitting. Failing that using the old shower outlet, but extending the waste pipe, to it behind the lining.
Fitting a bath to a boat and relying on gravity to empty it is a huge challenge.
Dare I say cassette or pump out loo. The difference in cost to change a pump out is likely to be phenomenal, both in cost and pleasantness.
Thanks, that’s promising. Hopefully I’ll be able to get a new hole drilled.
I had been thinking about a bath but that’s definitely something to consider. As for the loo, it’s a cassette: just a case of sliding it into a new room! -
I bought a NB that had the same done to it. It was done by a boatyard and the invoices in the pack of papers showed it cost £11,000 in labour. (£60 + VAT per hour)
Did they break it down? That’s about 153 hours, so I’d be interested to know what that went on. I’m probably going to do most of the work alongside my dad, who can turn his hand to most things I’ll need to do (plumbing, wall building) but won’t touch the hull.
If it was reasonable I’d pay for the majority of the hard work to be done, but by the sounds of your papers maybe not ?
1 minute ago, matty40s said:
Just turn the boat round, it's far easier and cheaper.
We've been planning a new galley for 18 months....
Not sure what you mean? There is a shower cubicle and a room for the toilet squeezed into the kitchen, I can’t leave it how it is...
Hi everyone!
I’ve recently bought and moved on to my first boat. My first job is going to be building a new, full width bathroom across the back of the boat, between the engine room and the living area, and removing the shower and toilet compartment to improve the kitchen.
I’ve got all the bits, and what I don’t have I’ll pick up second hand so I’m more interested in the cost of materials and labour for modifications to the boat itself (new drainage points, and a new wall)
I hope that’s makes sense. I’d also love to hear any tips and advice from your own experience
EDIT: As much as I appreciate the good intentions of those warning me not to do it, I’d much rather you didn’t.
Cost of moving a bathroom
Thank you for the concern but I did say this is a rough first draft, the only reason I shared it was to demonstrate the layout in terms of where everything was.
I understand that it isn’t technically correct and there are many things to consider before I start building but I’m really here for tips and cost estimates for the bathroom... thanks!
That sounds scary! There is a hatch, bedroom-side of the kitchen which will do perfectly as a fire escape ?
