Mary Rose
Everything posted by Mary Rose
  1. Oh I see I would be super careful in that case! Sweden have similar situation but not lockdown more to be careful and respect. Take care to you.
  2. Hi Yes I did and its spinning, ordered a new button display now! THANKS ALOT!!
  3. Hi Ok so by the fact i didnt have solenoid click and the green light never came on despite my 14V reading on the display side it was obvious that the display was malfunction. By shortcutting the connection 1 or 4 on the 4 pins the motor was turning like normal. This means that the display causing this and need replacement. Will follow up when its changed. Thanks all for super quick response. Stay safe in this C times!!!!
  4. Ok Will disassemble it today and try that, maybe the silver anodes. Well it spins a turn with remote controller and cant be overheated just used it for 3 seconds. It never get green so I cant even start it from the normal buttons.
  5. Bow thruster Engine. My main diesel engine is all good. I can add that I also have a remote control to it and then its actually activate solenoids and spin the motor a turn but then stops, then the sender goes red indicating there is a fault. I tried already with different charged batteries. I measured voltage to the engine 13,4 Volt.
  6. Only bow thruster is not working everything else work very good, electric furling is connected to same battery bank as the thruster and is working very well. Yes fuse is good and sorry for my wacky english
  7. All batteries are in good shape have 2 batteries to the thruster and 4 to domestic and single to engine. It was working good for 3 seconds then it died. Can be that my brother pressed left and right in same time not sure though. I can see that are charging both from landpower and engine and its up to over 13 volts.
  8. My normally reliable thruster wont work anymore. I pretty technical checked batteries 13,4V all fuses are good. Symtom when press on-line quick beeps till it goes back and never goes green or on-line. The engine will not start of course. Solenoid will not click either. Any suggestions.
