BIG DOG BONGO
    Ashby Canal
  • Occupation
    Staff maker Tilden Staffs
  • Boat Name
    FISHER
  • Boat Location
    Ashby Canal
BIG DOG BONGO's Achievements
Gongoozler
Gongoozler (1/12)
  1. Sir Nibble you are a true gent!!! thank you so much and to TB, Nut Thank you guys. I will get one ordered and do a wire fix for now.. Thank you again
  2. Thanks guys it’s the red light not the ignition switch that was lose so when I tightened bolt the light does not work! Since the light isn’t working for some bizarre reason my batteries are not charging from alternator. So I’m assuming the light being on has something to do with that! I really don’t know! So replace the bulb and bush bash bosh! Should work again?
  3. Thanks for the speedy reply. Ive checked all the wires there all still in place.
  4. Hi just tightened up my key ignition on my thornycroft board and my red light has gone out and my batteries don’t seem to be charging... god knows what I’ve done, can anybody help before I open the Rum to lower my blood pressure ??
  5. I’m Thanks Tracy will give that a whirl tomorrow and let you know how I get on ??‍☠️
  6. Thanks guys, great advice. Yes they where tight on the end one which is leaking. Yes it’s the top pipe as attached. Tried tape no luck with that and tried a copper washer. It does seem to slightly be out of line. Is the solder any good? How would you do that?
  7. Can anybody tell me where I can get the top injector pipes or seal? Linking fuel! Cheers ps the top one has worn and it’s a Thornycroft 108 engine
