Peeps.
I am after some guidance re changing anti-freeze in Isuzu 33 engine
At the moment the water is a dingy brown so unable to state colour of existing protection be it red, green or blue, I doubt if it has been changed for years.
I have searched previous questions on forum re suggested methods of draining system, but am still a tad confused ( I know, must be a age thing) on a couple of points.
If I drain the skin tank via removing the bottom hose presumably the calorifier will also be drained, will the calorifier require bleeding on refilling, if this is the case does it have this facility?
Would you recommend flushing system before adding any inhibitor and new anti-freeze or will this cause more problems than cure.
Is there a bleed point on the skin tank?
What colour anti freeze do you recommend?
Thankyou in anticipation .
Malc
