moiuk
Posts posted by moiuk
33 minutes ago, Mike the Boilerman said:
Hmmmm I don't think so
Reading the spec it only talks about limiting the charge current which is not the same thing at all.
Unless I'm missing something after several good whiskies!
My understanding is that the victron smart battery sends a control signal to the 10/200 BMS when it is full (and also if it is less than 5 degrees) to shut off the charge.
The victron 12/200 handles the overcharging issue I believe. It needs a normal battery to dump into when it shuts off to the lithium though.
Perhaps it would be a better approach to upgrade the second alternator to match the 95amp and drive 2 x 95a rather than 1 200amp ? Will the beta 43 handle that ?
Hi all, I am looking to install lithium batteries and want to reduce my charging time down to the smallest possible time. I am thinking of upgrading the existing 95a alternator on my beta 43 to the largest possible which I think is a 200a alternator.
I was going to use the victron 12/200 to limit the pull on the alternator to around 160Amps so as not to overload it.
Could this approach work? And where is the best place to get a 200Amp alternator for my beta 43 ?
Sounds like my takeaway is that the cheaper Ebay units are not for me
a choice between a new webasto and eber I guess. Which one is quieter?
Thank you. Yes solid fuel stove will be the primary heating source, but will need the diesel heater for those odd chilly moments and for the hot water when not running the engine. I am being quoted £2000 for an installed webasto which seems a long way from the £400 refurbished ones on Ebay. I'm happy going new if it's more reliable.but seems like a big gap....
Instant gas water heater could be a good option too...
Hi all,
Recently acquired our first 61' Nb and looking to live aboard in place if our rented accommodation. The boat is in need of a new water heater with the current Makuni mx60 being non functional (and all advice so far is not to bother with the expense of trying to get it fixed).
I am looking for the quietest option and with little experience do not know which model to request is installed. Webasto or eber seems to be the 2 main options but beyond that I am at a loss.
Big (expensive) decision so thought I would ask for some much needed guidance from the experts ..
Is there a best choice for the quietest model I should have installed ?
Boat has 4 radiators and a calorifier that need heating.
Lithium charging via large alternator ?
Posted · Edited by moiuk
I'm not sure, how could I tell by looking at it ?
Thank you, I'll try and give beta z call tomorrow.
