Martin Kedian
Days Won
2
Everything posted by Martin Kedian
It only went 20 miles before it was dry docked and a full repaint and fit out inside was done
Your so kind
Yes your correct however with new members joining some may have missed it that’s my excuse
It’s back in the water
Bars for symmetry and easier to leave rather than grind out the fully welded box section
Opps bad memory better second time around sorry very remiss of me just scroll on past !!!!
Change a window to a porthole or solid panel
Martin Kedian replied to Martin Kedian's topic in Boat Building & Maintenance
Well done him. If the window was cut in the right place first he wouldn’t have had to -
Best of luck -
For sure I have done a few but a right pain the recessed panel looks very boaty -
Thank you. One of my more interesting jobs is hollow and has a socket so as to put oil inside as a protective film It was made to hang on two brackets so can be remounted so as close to the original as possible I copped an original which was unfortunately rotten I felt Steel was a good medium to offer longevity
12 feet in length and it handled very well it was a Russet Newbury
Hmm let me see CRT perhaps
Perhaps we could Teflon coat the hull to 100 microns
Why do I have the feeling my post has been hacked does the underwater shape of the boat have and effect on this ie a chine length of swim distance from counter to prop pitch and size of prop shape and length of bow double or single curvature. Bitumen or two pack any answers on a postcard
And breathe deeply and slowly Ahh
Thank you a solution can be to change the prop to a heigh efficiency one
Yes they do especially as they are a tug style we put 3 two inch pavers in each floor space
No removal of ballast more added as displacement area is bigger
Engine size is important and should be taken into consideration
It’s only undercoat
A base plate of 10mm 3 Metre 1500 is now around £975 plus VAT
