Everything posted by Seren-y-dwr
Yep still got power and agree need to get it sorted thanks all happy new year to you all
Don’t know tbh (am s**t at this stuff) however I checked all the connections and a lot of water came out of this (pic) since I did this the trip has not tripped - about 10 mins now - so I could have been this
Am going to try suggestions and will report back - thank you to all
It’s just the switch shown in the pic that trips (on front of bollard) when I swopped over this tripped on the other outlet which suggests it’s something to do with my boat have only just come back on board after 6 weeks so boat is damp boat is v old (30 years) and mainly 12v with 240 only for plug sockets when on shore power - don’t run kettle or any other electrical devices on board Am going to look and see if I can see rcd
Thanks everyone for suggestions and questions will try drying yes is bollard at marina - there are two boats plugged in 2 or 3 minutes - that’s what is confusing me as I would think a short would happen immediately? will update
Hi hive mind any idea why? Will obvs discuss with marina tomorrow but just can’t work it out after 2/3 minutes switch on shore charger flips off have tried with my power off and neighbours (shared charge point) on and still happens have tried with engine running/not running have tried with heating running/not running think it’s my boat or the shore line?
Hi my bowman cap (no I didn’t know it was called that either) has a hole and the engine overheated i have a new one - the question is does the water/antifreeze I put into the heat exchanger also go into the swim tank or are they on separate circuits? I have a thornycroft Mitsubishi 3cyl engine - pic of bodge job used to get me to a safmooring on the avon
thanks all for advice, understand red fades - problem is i like the colour! So i think i will have to live with the fade.
- 15 replies
- frequency
- professional
(and 2 more)
Tagged with:
thank you lady and alan - what i am trying to work out in my head is if i should do a crap but prob ok ish job myself or go professional - i am still mulling at the moment
- 15 replies
- frequency
- professional
(and 2 more)
Tagged with:
look - i know all that assume competent painter how long will it last ? Seren-y-dwr narrowboat .pdf
- 15 replies
- frequency
- professional
(and 2 more)
Tagged with:
so blacked to gunnels by ABC and painted red above that by them in 2017. Some areas seem undercoated, others dont, overall dont think its very good. So I have been topping up myself. However i would like to know if a reputable painter did a job - how long would you expect it to last?
- 15 replies
- frequency
- professional
(and 2 more)
Tagged with:
Hi all and hive mind - question: how often does a boat need painting? I had a professional paint in 2017 but blacked to the gunnels. Paint is now looking tired and i have topped up/done areas but am unsure how long a professional paint job should last (am not impressed with job done btw). I did try to search google and this site for this but have had no joy.
- 15 replies
- frequency
- professional
(and 2 more)
Tagged with:
hi - yes cold water is not affected
Hi Hive mind Until recently I didn't have a problem with hot water being delivered from either the engine running or the eberspacher heating system. However, recently we nearly ran out of water in the tank - since then the hot water delivery has been poor with the water pump firing intermittently (on/off and not enough water coming out of the hot tap). Do people think I have managed to get an air lock in the system due to running low on water in the main tank? I have attached a photo of my water tank - if I turn the red knob at the bottom it seems to trigger the water pump and ?fill the tank - I then get better hot water delivery for a min or so before I goes back to the intermittent pump thing. Can anyone tell me what they think is going on and what the red knob does? Thanks
thanks Alan
lol - yes but a bit extreme!
Hi all, Can anyone tell me if there is a way (apart from lifting and trying to work out which one is heavier) to tell how much gas is left in a cylinder and if one of them is empty? Pic attached.
Starter battery help please
Seren-y-dwr replied to Seren-y-dwr's topic in Boat Building & Maintenance
actually got this one and fitting tomorrow (delayed going to boat). Even if there is a charging problem (which there might be and I know what to look for) the existing battery is a number of years old before I got the boat 2 years ago so - hey. -
thanks all - going to boat tomorrow (without buying new one at moment) to check all this love this forum -
Hi all My starter battery dies last weekend (managed to keep going jumping it from the leisure) - tested and was 12.2 from the multi Assume this is therefore dead as A its quite old B I am sure the charging is ok as had new alternators etc in last year and leisure are ok Can anyone advise me on what starter battery I need to get? Ideally from somewhere like Halfords (as there is one near me) not bothered about cost - want it to work and be low maintainance Engine is an old (1993) Thornycroft Mistubishi K3D thanks :)
