Sofia
Posts posted by Sofia
3 minutes ago, OldGoat said:
Before everyone else jumps in, I'd suggest 15w/40 it's a mineral oil with plenty of body - ideal for commercial duty engines
Folks on here suggest 10w/40 which (IMHO) is too thin and may not lubricate too well in an old engine. Someone at Beta Marine nearly exploded when I suggested 10/40 (I had loads of it). But times change.... The basis is that 10 grade oil is semi-synthetic and is too slippery, that encourages glazed bores = smokey exhaust (you don't want that)
Comments will doubtless follow - and I'd be interested to see their arguments...
Thank you
Hello,
I have been trying to find online before asking on here.
Our engine needs an oil change but I am not sure which oil I need to purchase for our Isuzu 33 hp - Engine type 1m4lb33 ?
Would anyone who has this engine or knows what the correct oil is please?
Thank you in advance
I have to say canal world is great. So many helpful people. Thank you everyone, it's all a learning curve for me and I want to understand everything I can. Thank you to everyone who has commented, definetly helped me
- 2
I have just had a look at the cables and they are 10 awg 6mm2 and I would say probably 4m in length to bus-bar ?
Thank you guys
6 minutes ago, Alan de Enfield said:
Basically - yes.
It may work, it may not. It depends on the wire size and distance from the battery.
But - if it doesn't work you will have a least a starting point for investigating the fault.
So I wouldn't ruin the fridge just testing it out?
7 minutes ago, dccruiser said:I would follow the 2 wires in your first pic, i think you will find they go onto spade connectors at the back of the fridge where the other wires are connected , if so i would pull them off there and just put spade connectors on your "new" wires and connect in the same way they were connected , rather than having an unnecessary join a foot along the wires.
Rick
Thanks, that makes sense
15 minutes ago, Alan de Enfield said:
OK, then the battery charger will be 'masking' any inadequacies in the wiring and volt drop.
Just be prepared that when you 'cut the umbilical' you may (or may not) find that your fridge / freezer works ok during the day when the engine is running, but overnight everything defrosts.
I had exactly this problem so it is not just theory.
My fridge was only about 2 metres from the Bus-bar supply and I had to rewire with 8mm squared (NOT 8mm diameter) cabling to get it to work correctly.
Ok thank you. So in theory if I connect the wiring up to the previous fridge wiring then it will work when connected to shoreline but when disconnected from shoreline it might not work as the cable is not providing enough power?
36 minutes ago, Alan de Enfield said:
Are you connected to the 'mains' (shoreline) & is the battery charger switched on ?
Yes sorry, connected to shoreline and charger is on
36 minutes ago, Alan de Enfield said:Are you connected to the 'mains' (shoreline) & is the battery charger switched on ?
The previous fridge was a reggio and it was only recommend from what I can see as short term use. The boat is currently moored in a marina and the voltage from the live cable mentioned is at 13.5 and then I tried the old fridge on 240v and still no colder.
13 minutes ago, Keeping Up said:
If the wires used to run a fridge ok, the chances are that they'll be ok now because the new fridges are generally more efficient than old ones, except that as the new one is a fridge/freezer it may need more current especially at start-up.
The old fridge was a cheap one which did not run well in the first place, as I don't think it was meant for continuous usage. Do indeed to follow the cable back the batteries, unplug, crimp wires and the connect back up to the batteries ?
7 minutes ago, WotEver said:
Yes, red connects to red and black to black. Hopefully you have noted Shoreline’s instructions as to cable size for the feed? And fusing? Ideally the connections should be crimped - it needs to be a really good connection.
The live wires were already behind our previous fridge in which must run directly to the batteries. I did notice the cable length, they must no more than 5 metres long.
Hello, I have just bought a Shoreline FD171 fridge freezer. It arrived and I didn't realise they need to be installed as there are no power connections. Do I really need to get someone to install it or can I connect the red wire from the fridge to the red live wire and the same with the black? See pictures. Any advice would be appreciated please
Thank you everyone
Thank you
Hi everyone,
I am looking to purchase a glavanic isolator plug in one for the boat as it is currently on shoreline.
I am currently looking at them but there is different amps etc. Which one should I get it?
I have seen some from 500amp or 1000amp etc. an example https://www.ebay.co.uk/i/291931699806?chn=ps
Do you have any recommendations ?
Hi
My boatman multi fuel stove glass has fallen off the door (not broken) and I am wondering what glue/adhesive to use to put it back on safely. Heat resistant? Any recommendations?
Brilliant. Thank you
Hello,
I hope you can help please. We are plugged into the shoreline and we have a sterling pro charge ultra. Do you leave this switched on all the time ?
Thank you all. I managed to get the filter off and give it a good clean and now it is working fine
Okay brilliant I will try this. I assume the filter is in the in pump? Thank you
Hello everyone,
I hope you can help. Our water pump stopped working and I gave it bash and it started working again. From what I have read online it could be work brushes? I have ordered a new pump to replace it however this morning I had shower and now the shower pump is on and making the noise but it is not pumping out the water. The pump is situated under our bed and I can get to it. Does this need replacing also or can it be fixed?
Isuzu 33 hp - Engine type 1m4lb33 - Which oil?
in Boat Equipment
Thank you
Thank you
