HI all,
We have just joined the forum and we are looking to buy a narrowboat and considering one we have just viewed.
This is hopefully where all your experience will be helpful, so we will thank you all in advance.
The boat we viewed has a Kabola E5 boiler installed and as far as we have found out this is not a bad thing but the querie we have is that it appears to be tapped into the engine cooling system, this he tells us is so he can also use the engine to heat the rads, but it means that the coolant reservoir cap on the engine is now redundant and he has installed a high point header tank that tops up the radiators as well as the engine coolant.
We should probably also mention that he installed it himself and although he is not a heating engineer he does however appear to be very competent. He did work in a boatyard for a number of years, which does check out and the boatyard owner did also say that he was very conscientious.
Is this OK it just seems to us to be unconventional and we just need some reassurance!
Thank you
Paul and Debbie
