Notice: I wanted to post this in the topic "I am sinking" in the FAQ but it is locked so I put it here.
Hi there,
Like many other people before, I have some water problems in by accommodation and motor bilge. I read quite a lot of threads in this forum and elsewhere to know how to solve the problem, but there is one question I could not find any precise answer for: how detrimental is it to have a bit of water or dampness in the bilges?
Here is the background of my question.
Chapter 1 - Accommodation bilge
A few weeks ago I opened the hatch to look into the accommodation bilge (which is at the deepest point of the cabin) and discovered with surprise it was full of water. I mopped up the approx. 30 litres of more or less clean but reddish water and went through forums to find possible explanations. I checked all pipes I could find, looked for signs of dampness, checked the wall insulation where I could access it and looked at the windows to find possible sources of leaks. Of course I could not find any leak so far. I expected the water to come back in the bilge (I continued to use domestic water normally and there has been quite a lot of rain falling), but surprisingly after 3 weeks I couldn't mop up more than 1.5 litres. I even suspect this water was not new, rather some water I missed out the first time I mopped up. There may be a small leak somewhere, though, because the water pump would kick in a few times during the day, like 5 times per 24h for less than a half second each time. Also my heating system tends to "consume" water. I guess it will take time to find the leak, which I now expect to be very small. The 30 litres I mopped out the first time may have been accumulated over months, if not years.
Chapter 2 - motor bilge
There is always a bit of water there. I moped approx. 7 litres a few days ago and after two days the water was back again. At the deepest the water is about 1 to 2 cm, so the bilge pump wouldn't even activate. The water is in the motor tray and in the compartments on each side of the motor tray. The axle/shaft to the propeller/screw is well greased and tight. No water coming from here and the compartment below is the only one which is dry. I suspect the water to come from rainwater (once again, it rained a lot), condensation (the ceiling of the motor room is full of hanging droplets longing for freedom) or some default of the calorifier.
Long story short: in both cases, it is not a massive amount of water and I guess it will take time before I can get the bilges systematically dry. Should I worry about having a bit of water or dampness in the bilges? Will the hull rust, with risk of structural weaknesses? Should I worry my boat will sink one day or can I just lean back and relax because it is just normal to have a bit of water?
I am thankful for any hint!
PS: additional question: does it make sense to put computer fans to create a continuous airflow and keep the accommodation bilge dry? I read this somewhere and thought it makes sense, but I also read it is better to keep the hatches closed to prevent condensation... So I don't really know what to think.
