Ok, more info. On pre heat the alarm sounds and the warning lights come on. Once the key is turned to start, the engine turns over, fires and runs. The lights go out. On checking with the multi meter (this is our only battery monitoring) the alternator is pushing 14 volts into battery. Everything fine and dandy for a time with no problems . Then perhaps a couple of weeks later once you have started the engine you hear the pre heat alarm and see that the warning light is on. No output to the battery.
We suspect that this is a problem preceding our ownership as some months after buying the boat we twigged that the alternator wasn't working and spotted that the spade end connector to the warning light on the back of the alternator had been disconnected so there were no warning lights (and therefore it wasn't charging).
We have one starter battery and two domestic separated by a manual switch.
We have been told that this could be caused by turning the key to OFF before pressing the stop button, but the last time it did it, we are sure that we pressed the stop button first.
Any help would be appreciated.
