woodowl
Everything posted by woodowl
  1. Hi there Nic Thats ok We have the same inverter (excellent kit) with travel power 3.5kv, and 6x 110ah batteries, so it looks like another job for winter. Thank you for your reply
  2. Hi there Nic Thanks for info can you advise me on what inverter you have fitted. Chris
  3. Hello We have to disagree with you. We don't want to argue just an option to pump out in more places. ie Whaley Bridge. and also if there pumpout is broken. new guests empty tank. The money we spent on our kit adds up to a lot of boadyard pumpouts. So NO it's not about saving money. Thanks chris
  4. We Must be. o no a bigger tank Thanks chris
  5. Yes we know there's plenty of boat yards. but having self pump out helps when there is not. Thanks chris
  6. Hello So many comments, With us been a hotelboat with 4 guests and 2 crew on board cassette toilets would not be very good. its' not about not affording to pay for pump out we use boat yards or bw card pump out what ever is available. Where there is no pump out we have to use our 12 volt self pump out. The problem is due to the large tank the pump is to slow there for holding up every one which we woudn't do. Thanks Chris
  7. Sorry to talk about **it but with 4 macerator toilets and large tank on board and some blockages you get use to it. what we are concern about will our electrical system be ok to run it, on the data sheet the motor draws 4.4 amps but is there a way to work out the starting amps. Of course we would only pump out where available. We would also like to say what a good forum you have been a great help with other information we found keep it up Thanks Chris
  8. Hello Has any one got or tried out a Jabsco Utility 80 self pump out which is 240volts. What we would like to know is will the motor start, by using the power supply on the boat which is travel power 3.5 and victron 2.2 charger inverter. Thanks Chris
