Keith M
Posts posted by Keith M
Do not forget there is also a 3 % volt drop rule for essential items of equipment such as bilge pumps etc.
This is a requirement of ISO 13297 which now also covers 10133 from January this year.
I would have a look at Aqueduct Marina
8 minutes ago, David Schweizer said:
Is there a viable alternative to cooking with gas on a boat? (and please do not suggest a primus stove!!)
What about a diesel stove?
EN 10133 has now been amalgamated into EN 13297. These two standards are for DC and AC cable installations.
There have been no changes to either standards since 2013
Could it not be a wiring fault.
Is the ignition warning light extinusing?
What happens to the alternator if it is not spinning at a speed so that it does not overheat
The best way to recharge lithium is to use a battery to battery charging system.
Fenner Power transmissions
Will be able to supply the pulley and taper lock.
A number sleeve is more than adequate and cross reference it, or use a colour code again needs to be cross referenced
All new craft should have all cables marked it is a requirement of the Recreational Craft Directive
- 1
If I try and pay in more than 2K in cash I normally have to speak with the manager
When supply power electronics I often get this amount of cash.
The rules are changing all of the time
Good morning
Which area of the canal system are you based?
I have installed many BTM-1 over the years I would be happy to take a look.
Battery voltage does not need resetting, this sounds like a wiring issue?
The manual should be on the web site, I will try to find the link
- 1
I would use one of the many fire stopper products
49 minutes ago, Machpoint005 said:
So competent that they apparently didn't know the rules?
Yes they were aware of the rules but by waiting for an ambulance it was going to around two to three hours
Sadly two competent officers have resign because of a formal warning, because they took a injured man to hospital.
all of that experience and expertise has been lost.
It was not because they did nor what for a ambulance but because they used a stretcher in a private vehicle
Another vote for Pete.
The person who works from his narrow boat could have the same qualifications as using someone from a boat yard
Over heads will be slightly less.
A small example public liability insurance is over £ 1000.00 per year.
Most boat yards and individual technician will be charging around £ 60.00 per hour.
As an individual I feel this to be a fair price for my skill and knowledge.
- 1
You could try Key Diesel from Burton-on-Trent
Is the breaker you are using design for an AC circuit or a DC circuit?
The IET recommend H07 RNF for marine applications.
And before anyone starts I am fully aware that at the moment the IET has no jurisdictions.
- 1
I was at an installation yesterday which has a BMV 700 & 712 installed, both will not be operational for some time yet, However, I look at both manuals and they give the impression that the 712 has an internal buzzer. I would now talk to the supplier?
Having now read the manual. I will also check on Monday, I am working on an installation which is using a BMV 712
If the buzzer has been activated and all the setting is correct it may be an issue with the monitor itself.
I would suggest talking to the supplier
Electric cables via engine bay accepted by BSS?
This is a simply question to answer use 10 mm cable from the Batteries directly to the Fridge using the correct protection
