Keith M
Posts posted by Keith M
Hi gurus,
I want to connect my Mastervolt system together, to make what is almost my dream set up.
I bought Borah a 2001 Dutch Barge and she already had a Mastervolt (MV) Whispergen 3500 and a MV 60amp battery charger, but no inverter strangely. I have just purchased a MV Mass Inverter 2000 (I would have liked to replace charger with a combi unit but a good deal came along on inverter so...)
Firstly can I connect them all together, if so what benefits do I get and secondly how the hell do I do that and thridly what would I need to get to do that. I would also like to add a battery display monitor, I do have a Adverc DCM III unit form my old boat I never fitted and have the shunts and bits for that (though no wiring diagram). Would prefer a Mastervolt monitor to keep the system all MV. Does anyone have any suggestions on a unit suitable?
Other details - 330amp/h domestics, 110amp/h engine start - I will not be running anything massive off the inverter, its just everyday items such as TV, power tools, stereo, iMac etc etc
Any help or advice as ever gurus would be much appreciated.
Thanks
Ian
Hi Ian,
I sent you a PM which I hope that will help
keith
We have a Mastervolt Mass Combi (Sine Wave Inverter/Charger with Generator/Mains Support) with the basic indicator panel - sorry, don't know which model as I am at home with only the generic manual to refer to - and a Dometic 230 V Travel Power Unit.
Normally, when we are going along, on the panel the inverter light goes out and the charger light comes on, indicating that the inverter is operating in charger mode and doing it's 3 phase charging thing. This weekend, I noticed that when going along the inverter light stayed on, which would indicate that the inverter is not going over to charger mode. The batteries still charged, but I would imagine that it's better to 3 point charge via the charger than not?
All the lights are green, everything looks good to go and we haven't fiddled with anything. These seem quite clever bits of kit, so if anything was wrong I would expect to see some kind of indication in the form of a red light or a buzzer. If you stick your head in the cupboard and look at the actual unit itself, the AC light on the inverter seems to flicker. It seems to me that either the Travel Power is not producing electricity, or it is and that the Inverter somehow isn't registering this. This has happened a couple of times before, but seems to sort itself out.
Mr Hum is completely befuddled with the whole thing, and suggested that perhaps the batteries didn't need charging enough to warrant the charger kicking in, but that doesn't seem like a very plausible explanation to me, particularly as we'd been moored up overnight with the fridge, lights, etc, on.
I've had a read through both manuals but can't see anything that would explain it. Can anyone offer any advice, or point me at where I should be looking?
Thanks.
Mrs Hum
Thanks for your help Keith - I'll keep this in the open forum if that's Ok so others can benefit.
As I read the the instructions there seems to be the ability to vary the charger ouput using the Masterlink remote controller but that this is enabled up using the dip switches in the Mass Combi itself.
I'm guessing then that if I can succesfully vary the output using the master link controller then the dip switch is correctly set and this feature is enabled, if not I'll need to enable 'power sharing' using the dip switches.
alternatively I see that the output can be varied with a combination of dip switch settings - presumably this is for when a remote Master link controller is not installed????
It is quite common for installers not to read the installation manuals so therefore the The combi is very rarely set up correctly.
If you have an MICC remote control fitted it is very to set up the power sharing if not you will have to use the dip switches
If any of the manuals are missing there can be down loaded from the Mastervolt web site.
I hope this is helpful.
ABout the key, I think that they might be generic keys, I am sure that it has been mentioned on the forum before. Alternatively phone a swindlers to see what they say.
About the hour counter, keep a log on a bit of paper for now. You could replace it with a digital hour counter from ebay such as this. clicky
You Could try contacting Engines Plus for a replacement key
I think you could be right - just trawled through the in depth manual which makes reference to setting the charge level via. the remote controller....it seems it can be reduced... will try next time we are aboard.
Many thanks...
For the Mass Combi 12 / 4000 / 200 to function correctly the input current required needs to be around 17 amps
Inside the unit are two rows of dip switches you can limit the input current via these dip switches
Please PM if you need any further help.
Hi All,
I have been searching for this relay with out any success
Can any help
Many Thanks
Hi
Contact Keith Meadowcroft, AKA Volt Master and a trouble shooter for Mastervolt. He's an authority on their systems and will be happy to help. Mobile 07740 200 775
Cheers
Dave
Try disconnecting the battery temperature sender from the battery charger.
I have been adding some replys for a day or two as I am a new member.
Which ever meter you buy if you can run to the eacher cost pick a ture RMS type of meter with a good resolution.
Hi
I have been involed with installing AC and DC system in all types of craft for more than 20 years.
You get what you pay for, take a look at Mastervolts BTM 3.
quote name='Moisha' date='Jan 29 2007, 03:45 PM' post='103886']
Hello all--now that we are edging our way toward electrics--the stove is in!!!!---all sorts of electrical queries will be flying your way. We were told that as we will be living mainly off batteries and with little access to on-shore mains electricity, we must invest in a battery monitor/shunt. The prices quoted have been exorbitant and I was wondering if any of you had suggestions for reliable yet not scrape-the-crumbs-out-of-the-wholes-in-your-pocket monitors. I came across these on line: http://www.yachtbits.com/nasa/nasa_clipper...itor_system.php, but was told that they are not accurate enough by a salesman for VoltMaster. Is that true? Because 80 quid seems ok, but 300--not! Any shops/websites for these things that you would recommend?
Thanks again--don't know what we would be doing without you, Fine People.
Mosha.
Hi what was the voltage of the batteries before you stated the engine
Gel batteries have a very slow discharge rate
hi folksjust a couple of questions for the technical minded amongst us, or even any one who may know the answer.
My boats not had its engine run for nearly 6 months and as such the domestic batteries have slowly lost whatever charge was in them over that time, they are 2 200 amp gells from mastervolt and are abouht 2 years old, over the weekend i went on the boat to do some jobs and took a fully charged start battery with me and she started first time.
i ran the engine at around 1100 to 1200 revs and initially took no notice of the digital amp indicator which shows the rate of input, after abouht an hour i noticed it hovering between 19 and 20 amps going in which for a set of batteries that i thought were prety flat didnt seem a lot, in response to this i bumped the revs up to 1400 and over, and the indicator stood firm at 20 amps, no fluctuating just 20 amps dead.
now previous experience has shown me that the alternator or the seperate controller ( whichever is responsible) usally kicks of at somewhere between 40 and 44 amps input for a while and then the charge rate drops of over a few hours finally indicating a full charge at a 3 amp input.
So the question is does the low start input amperage indicate something possibly wrong with the charging system considering the domestic batts must have been well flat ,and why so early on in the charge cycle would the display show a fixed 20 amp input with ever increasing rev speeds, furthermore what harm if any has been done to the 2, 200 amp gells by letting the previous full charge dissapate over time
Thanks
Bendyboat
Hi if you were thinking of having a Tug style narrowboat build who would you have build the shell???
David
In my opinon there is only one builder to who can builder your new boat that is NORTON CANES BOAT BUILDERS.
help in checking wiring for 240v
Posted · Edited by Keith M
I would suggest
Shore in - RCCB - Isolation transformer - RCD + 2 circuit breakers 1 for the combi and the second for the immersion heater
Combi - RCD plus circuit breakers for various circuits
This should comply with Regional craft Directive and BMEA code of practise for AC electrical installations
A RCCB is a RCD + a circuit breaker in the same unit
